Hi guys,
After reading quite a lot about building, hardware, ZFS, if DIY or prebuilt, I have come to conclusion, that for my needs and my level of knowledge, a FreeNAS is most likely the best solution.
My requirements:
- storage server for all my photos/videos/movies/documents with lots of space and expandability
- reliability with redundancy and failure safety (yes, most important data will be saved externally too, most likely 2nd 4TB NAS, the one I have now)
- possibility of future upgrade without having to invest 1000€+
- low power usage
- ability to run bittorrent and other similar programs (sabnzbd, sickbeard etc...)
- real-time 1080p mkv transcoding to mobile device(s), but one at the time (most probably Plex)
- Gigabit network, speeds around 100 MB/s wished and hopefully achieved (single CAT6 cable)
- sleep ability, but would like the power up ability like the current cheap DLINK NAS has, by accessing it, it wakes up (no WOL)
Currently provided networking hardware is ASUS RT-N66U router, Cisco SE2500 unmanaged switch, fully CAT6 based network, including CAT6 patchbay and wall-connectors (all CAT6 certified), self-made. Quite some knowledge about unix-based commands, not complete newbie here (also have OSX, and using Terminal quite much), however no unix expert. I find my way around when I need stuff, Google is much help and forums too. I am no stranger to tinkering and self-configuring, if it's not overly too complicated.
So, after some research, I have finally set up something that I think should serve for the time come:
Server MB Super Micro MBD - X9SCM - F mATX Intel LGA 1155
Intel Core i3 - 3240T 2,9 GHz ( Ivy Bridge ) Sockel 1155 - tray
Scythe Katana 4 SCKTN - 4000
Kingston D3 16 GB 1333 - 9 REGP Dx4I K2 KVR (KVR13R9D4K2)
ServeRAID M1015 SAS, SATA Controller
4x WD 8,9 cm ( 3,5 " ) 4 TB SATA3 WD40EFRX 64 MB Red
LC - Power 300W LC7300 80 + Silver Shield 12 cm V2,3 retail
NZXT SOURCE 210 ELITE Midi - Tower
This build goes total for 1379€. A little higher than planned, but it should provide for everything I want in my requirements.
So, how does this build sound?
The memory is not found on the compatibility list of Supermicro, however they list very little tested and compatible memory. Is this memory OK? For the beginning, as I start with 16TB pool, I take 16GB RAM. Later possibly expansion to 32GB.
The mainboard, there are many choices, I went for C204, as the board is 20€ cheaper than C202, and I see no disadvantages.
I have chosen the 3240T as it apparently has no disadvantage over 3220T when it comes to power usage on idle, and it provides a little more power when needed. The price difference is also merely 15€, so not really an issue. However, if I take 3220T, I could buy the boxed, and save money on Scythe too. However is 3220T enough for transcoding 1080p MKVs? I read somewhere that 3Ghz is recommended.
M1015 comes recommended as the FreeNAS SATA card, I know I have to mod it, have no problems with that (there are no eBay articles on this one, and none cheaper), cost me €151. I like the idea of not running the stuff off the board.
4 WD Reds are for the beginning (RAIDZ), I would like to start with 1 drive redundancy, and later expand the zpool with additional 4x 4TB drives (2nd RAIDZ). However, if I understand correctly, if I do it like that, I will have 2-drive redundancy if only 1 drive from 1st vdev fails and 1 drive from the 2nd vdev, but if 2 drives in the 1st vdev fail, my whole zpool is going down and I am fucked. How high is the probability that two drives die at the same moment? The whole server will be in the cellar, which is a fairly cold room, so the heat shouldn't be any issue. The case will also be well cooled. Noise is not a problem. Buying 8x WD Reds with 4TB is a no go. Buying 8x 2TB Reds might be an alternative. I wanted to avoid buying 2GB disks if I already plan on going 4TB versions. What do you think?
PSU - that should be quite OK PSU for this server? I read it's recommended and quite good when it comes to power usage.
Case - well, I wanted 19inch rack with slots from the front, but I can't find anything suitable in the priceclass that I can afford.
I hope I planned this carefully and hope you can give me some advice!
My requirements:
- low power usage
