Complete and utter stupidity with permissions
joeschmuck
Old Man
Just out of curiosity should I delete everything here you think and just start everything from new? I think that would probably be the best option?!?
drwxr-xr-x 2 root wheel 18 Jan 31 2015 .VirutalBox.meta/
drwxr-xr-x 3 root wheel 3 Jan 25 2015 .plugins/
drwxr-xr-x 5 root wheel 5 Dec 3 2015 .warden-files-cache/
drwxr-xr-x 17 root wheel 23 Jan 31 2015 .warden-template-VirtualBox-4.3.12/
drwxr-xr-x 18 root wheel 22 Jan 25 2015 .warden-template-pluginjail--x64/
drwxr-xr-x 18 root wheel 22 Dec 3 2015 .warden-template-pluginjail--x64-20151206171428/
drwxr-xr-x 18 root wheel 22 Jul 9 19:09 .warden-template-pluginjail--x64-20160710083033/
drwxr-xr-x 17 root wheel 23 Jan 31 2015 VirutalBox/
Just the items which have VirtualBox in the name. The other stuff is just freenas jails stuff. But if you are doing a complete cleanup of all jails and plugins, then yes, you could delete everything listed above but honestly, I'd do the minimum at first and see if that takes care of your issues.
Spud
Yeah it doesn't really matter to me if I delete everything as the only other plugin I use is plex which takes all of 5 minutes to get going again.
I'm stuck on removing the Jails directory at the moment with this error
"cannot unmount /.warden-template-VirtualBox-4.3.12"
If I can just get my head this then I'm sure I can get this sorted
Thanks for the help!
joeschmuck
Old Man
In the GUI, Storage icon, now find the jails directory and delete it. Using the GUI makes things easy.
Spud
Yeah tried that and from the gui and cli as well and it always gives me this error
And I cannot seem to find any way of stopping/unmounting/killing anything to do with Virtualbox
The hunt goes on... :)
I will fix this one way or another
joeschmuck
Old Man
I know it can be done because I've been there myself many months ago. I just don't want to delete files on my machine to test it out. Did you stop all the jails and VMs? I assume so. Have you gone into a shell and tried remove the files? How about a reboot?
I'm sure you will figure it out. Best of luck to you. Time for me to make dinner, wife on her way home from work.
Spud
Nar mate don't go deleting files because of my stuff up!! :)
I have fixed the problem but not in the way I would have liked, I just copied all the files off that set of drives destroyed it and recreated it. Thats killed the jail directory!
One thing I have noticed after reinstalling VirtualBox and setting up a test VM to make sure things are working, which they are, And that is I didn't notice straight away a slight mistake in the copying command
cp -R SSVPN/ /mnt/Tank2/jails/VirtualBox/usr/home/vbox/VirtualBox\ VMs/
Which has created a new directory called VirtualBox\ VMs
Instead of
cp -R SSVPN/ "/mnt/Tank2/jails/VirtualBox/usr/home/vbox/VirtualBox VMs/"
I'm a little nervous about trying to delete the second directory called VirtualBox\ VMs is case it stuffs something up again :confused:
Stux
Is an escape for space. Both cmds seem equivalent to me
Spud
Well there are now 2 directories
1) VirtualBox VMs
2) VirtualBox\ VMs
The first one is obviously the one I want to keep.
styno
Now would be a good time to set up a snapshot policy ;)
Also, you can rename that directory first to something less dangerous and without a space in the name. If that goes well you can delete it..
The slash and space is there because of the quotes you used with the cp command, use them in the mv command to rename the directory and you'll be good.
Spud
Dude I have already got the snapshots working, once everything was up and running it was the first thing I did this is never going to happen again! :)
Cracking idea around renaming before deleting the directory thats also taken care of now.
Thanks for the help
joeschmuck
Old Man
So all is good again in the Spud world?
Spud
Yep and I can say with full confidence that I'll never make that same mistake again!
Thanks for the help
