command for deleting backup files after 3 weeks
yyhrzn
So I created a cronjob for backing up my SMB to a external usb drive (command: rsync -zvr /mnt/files /mnt/Backup/ --delete-after) but I want it to delete the files which were deleted on the SMB only after 3 weeks on the backup drive, not immediately (as in the current command), but I don't know the command for it.
and another question: is there a way to implement a encryption for the backup drive which doesn't stop the backup cronjob from working?
thank you in advance! :)
As a cron job (aka Unix command), it would like this: find /path/to/files/to/be/deleted -type f -mtime +21 -exec rm -f {} \;
yyhrzn
Thank you, but I don't want a specific path to be deleted after 3 weeks. My plan is to backup my FreeNAS SMB to a external drive. When I delete a file on the SMB, i want it to be deleted on the external backup drive too, not immediately, but in 3 weeks.
If you used a snapshot lifetime of 3 weeks and a replication task to move the data to the backup server, you would get the result you want (in a way...).
Actually what that would do is show the file as deleted immediately in both the production and backup systems, but in fact the snapshot (which would be on both sides) would have the file until it expires in 3 weeks.
yyhrzn
thanks, that'll work for me, but what do i choose as the remote hostname (external backup drive)/port?
Please do not use external image hosts. Instead, copy/paste your images directly into your message.
So you'll be setting the server to localhost.
You will want to turn on the options to delete stale snapshots and to replicate children (probably, depends on your structure).
Turn all of the encryption options off or set to none (no point doing this as the data never leaves the server).
You will need to set the SSH key for the root user (or the dedicated user you will use for the job) under that user's settings...
I'm borrowing this text:
Paste the ZFS Replication Public Key to root's SSH Public Key
from this thread (look at @Dusan's first post).
fracai
seeing as you're using rsync for your backups, I suggest you take a look at "rsnapshot". It will let you create incremental updates and prune old snapshots at whatever interval you want.
rsnapshot.org
yyhrzn
thanks, it's working now! :)
