VladTepes
- May 18, 2016
I just went to post a reply with some code inside code tags
I used the 'code' button above the edit window, which created the tags in CAPITALS
The code tags then didn't work.
I went back in an edited the post and manually changed to lowercase.
Now worked fine.
Strange.
Perhaps a problem with the 'button in that it should generate lowercase characters output rather than caps?
Now worked fine.
Strange.
