Clusters and Nodes
MurtaghsNAS
I am a new user, looking to set up a home NAS. SCALE seems to be an ideal choice for my use case of a media storage server with a few small, single user apps (Nextcloud, MythTV, Twonky) running "virtually." I currently have them running as VMs, but I should be able to refactor them as Docker instances as I get used to Docker. I am in the planning and architecting stage, so SCALE being in Beta doesn't bother me, as about when it is scheduled to be ready, I'll be ready to buy my gear.
When I first saw SCALE supported clusters, I saw it as the typical enterprise "collection of equals" used to guard against catastrophic node failure. As a home user, this didn't excite me because I was planning a single node, and can't realistically afford node redundancy. But after hearing people repeatedly talk about "storage nodes" and "compute nodes", I realized there was a possibility I had misunderstood the clustering design, and that it could really be much more exciting. Let me see if I understand properly.
Let's start with a node that is a perfectly balanced storage node. It has just enough processor power and memory to perfectly handle OS and storage tasks, and not a bit more. I decide I want to take advantage of SCALE's "virtualization" (VM, Docker, K8) features. Of course, this perfect storage node does not have the horsepower to handle "virtualization." Would I be able to add to the cluster a compute-rich but storage-poor node such as an Intel NUC to handle the "virtualization" load?
This Lego-brick style of clustering is really exciting to me because of the upgrade possibilities down the road. Right now the single node design I am working on is a bit overkill. I am allocating an over-large compute budget to the design because I do want the virtualization, but don't know what my needs and wants are going to be 5 years down the line. If I have the ability to add compute as a cluster feature down the road, I can right-size the initial storage node now, saving money.
Am I understanding TrueNAS SCALE's cluster design correctly that it is a Lego-brick style design where compute nodes and storage nodes can be added as needed over time, or am I misconstruing things?
So far, the "cluster" concept refers to 3 (or more) storage nodes which are set to manage content between them according to one of the options offered by glusterfs, so it doesn't match with what you're saying you want.
You could effectively do what you're proposing by using either CORE or SCALE as a storage node with a fast connection (usually 10Gbits) between it and other node(s) to allow SCALE to run apps (compute) by mounting NFS from the storage node and sharing it into the containers as needed.
That would detract (a bit) from the glusterfs concept of having the storage available locally/directly on any node that runs the container(s).
ornias
A little addition to what @sretalla explains:
- Currently only Storage clustering is available for SCALE.
- Container clustering (compute clustering, basically) will not be in the initial release of SCALE.
- Also be aware that NFS mounts for containers have some annoying downsides...
MurtaghsNAS
Thank you folks for the clarification. I was hoping I did not misunderstand, but it is clear my initial impression was closer to the reality.
When I get my hardware, I will be back!
