Cluster Creation Fails
cbben878
TrueCommand: 2.3.3
TrueNAS SCALE: 22.12.4
I have three hosts all running the latest TrueNAS SCALE version, and then a separate VM running the TrueCommand docker container. When I attempt to "Finish" the configuration of the cluster (Assign VIPs and connect to ActiveDirectory), it is failing with the following two errors:
[EINVAL] activedirectory_update.enable: At least one public IP address must be configured prior to joining Active Directory.
[EINVAL] activedirectory_update.kerberos_principal: Simultaneous keytab and password authentication are not permitted.
I had pre-populated the IP addresses in DNS (forward and reverse zones).
Any thoughts what could be causing the error?
