Clear smart ATA errors?
bogdanovvo
Hi all,
I am running nagios that checks status of the RAID drives on one my servers. recently one of the drives has reported an error. I was able to locate the drive and run a SMART check on it, below are the results.
Now I am getting bombarded with the warning messages from nagios about this drive, but it seems to be OK by looking at SMART report. I really wouldn't want to turn off notifications for this service in case something serious happens, is there a way to reset the error count on the drive?
Model Family: Western Digital Re
Device Model: WDC WD4000FYYZ-05UL1B0
Serial Number: WD-WCC132357965
LU WWN Device Id: 5 0014ee 20a992ba1
Firmware Version: 00.0NS05
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Feb 4 17:49:17 2020 PST
SMART support is: Enabled
SMART Status not supported: ATA return descriptor not supported by controller firmware
Warning: This result is based on an Attribute check.
General SMART Values:
was never started.
been run.
data collection: (45960) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 496) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 4
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 7386
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 4
16 Total_LBAs_Read 0x0022 007 193 000 Old_age Always - 414892220909
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 3
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 125 119 000 Old_age Always - 27
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 2
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 2 occurred at disk power-on lifetime: 36033 hours (1501 days + 9 hours)
ER ST SC SN CL CH DH
04 51 00 00 00 00 00
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b4 00 00 00 00 00 00 00 22:31:48.429 SANITIZE DEVICE
ec 00 00 00 00 00 00 00 22:31:48.429 IDENTIFY DEVICE
ec 00 01 00 00 00 00 00 22:31:48.415 IDENTIFY DEVICE
e5 00 00 00 00 00 40 00 22:16:28.558 CHECK POWER MODE
Error 1 occurred at disk power-on lifetime: 36012 hours (1500 days + 12 hours)
b4 00 00 00 00 00 00 00 01:07:28.991 SANITIZE DEVICE
ec 00 00 00 00 00 00 00 01:07:28.990 IDENTIFY DEVICE
ec 00 01 00 00 00 00 00 01:07:28.976 IDENTIFY DEVICE
ec 00 00 00 00 00 a0 00 01:07:26.434 IDENTIFY DEVICE
ef 02 00 00 00 00 00 00 01:07:26.434 SET FEATURES [Enable write cache]
# 1 Extended offline Completed without error 00% 7366 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
