Register for the iXsystems Community to get an ad-free experience
Cisco shows LACP not enabled on 11.1U2, BCM, 2960X IOS 15.2
justlikeef
Trying to get to a LACP Trunk config. First step is just LACP bundle in edge mode (no vlans) and bundle will not form. The FreeNAS side shows it as being active. The switch is reporting that LACP is not enabled on the individual ports. We have tried multiple versions of IOS from 15.0 to 15.2(6)E1. I have about 10 windows servers with the same NICs on the same switch that are negotiating LACP successfully as well as tagging vlans, so the hardware pieces seem to be OK. I have tried configuring from both the GUI and the CL with the same result.
Cisco 2960X
switch config:
interface Port-channel10
switchport access vlan 1900
switchport mode access
interface GigabitEthernet1/0/27
channel-group 10 mode active
interface GigabitEthernet1/0/28
logs from switch:
Mar 13 17:38:09.626: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/27, changed state to up
Mar 13 17:38:09.665: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/28, changed state to up
Mar 13 17:38:15.753: %EC-5-L3DONTBNDL2: Gi1/0/28 suspended: LACP currently not enabled on the remote port.
Mar 13 17:38:16.005: %EC-5-L3DONTBNDL2: Gi1/0/27 suspended: LACP currently not enabled on the remote port.
Switch#sh etherc summ
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use N - not in use, no aggregation
f - failed to allocate aggregator
M - not in use, minimum links not met
m - not in use, port not aggregated due to minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
10 Po10(SD) LACP Gi1/0/27(w) Gi1/0/28(w)
Switch#sh int gi1/0/27
GigabitEthernet1/0/27 is up, line protocol is down (notconnect)
Switch#sh int gi1/0/28
GigabitEthernet1/0/28 is up, line protocol is down (notconnect)
FreeNAS
ifconfig
bxe0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSU
M,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO>
ether 00:0e:1e:86:7c:70
hwaddr 00:0e:1e:86:7c:70
media: Ethernet autoselect (10Gbase-T <full-duplex>)
status: active
bxe1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
hwaddr 00:0e:1e:86:7c:72
status: active
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
status: active
groups: lagg
laggproto lacp lagghash l2,l3,l4
laggport: bxe0 flags=0<>
laggport: bxe1 flags=0<>
kdragon75
I don't recall, does the 2960X support port mirroring? do you have a hub? I would sniff the PDUs and see if there is an issue in link negotiation.
Either way I have never had any luck with LACP outside of linking matching switches.
EDIT: Derp just run a pcap and take a look with wireshark or tool of your choice.
justlikeef
Turns out that this is a known issue with the Qlogic driver that everyone thought was fixed, but was reintroduced at some point. Looks like it is not going to get resolved any time soon.
depasseg
FreeNAS Replicant
Try putting the bxe interfaces into promiscuous mode ( ifconfig bxe0 promisc ), then shut/no shut the switch ports to bring it up. This fixed it for me.
