Hello All,
This may be simple but wanted to check for best practices or what other have seen to be the most acceptable in the field. When creating an SMB share that is going to be shared out to mixed environments, both Mac and Windows clients, what permission scheme should be used? Mac, Unix, Windows? Also, does case sensitivity play a role in this?
As a side note, we also push clients that are all Mac users to go with SMB shares as Apple is SLOWLY integrating that into their wheelhouse. We are currently using 9.3.
I have deliberately kept our system specs out of the mix because this question should not have any bearing on that. I will say though that we use 32GB on up to 256GB of RAM for all systems and use enterprise SAS drives. I follow these forums closely and enjoy the input from the community and look forward to contributing where I can.
Thank you,
Devin
Thank you,
Devin
