CIFS fails after 9.3 201501301837 update
TheFlow
I've been trying for 10 hours to solve this problem.
After updating from 201501241715 to 201501301837 CIFS doesn't function as before. Shares are visible but not browseable due to incorrect credentials. Using the credentials with WinScp for instance, is not a problem.
Rolling back to 201501241715 solves it but i need the latest update. I'm not using AD or NFS.
Tried:
Changing password and then back to the same one.
Created new account, deleted share and added again.
Reboot, cold start.
Updating to latest 201502142001.
Switching to SMB2.
Smb4.conf:
server max protocol = SMB3
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 1884926
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = yes
directory name cache size = 0
kernel change notify = no
ea support = yes
store dos attributes = yes
hostname lookups = yes
time server = yes
acl allow execute always = true
acl check permissions = true
dos filemode = yes
domain logons = no
local master = yes
idmap config *: backend = tdb
server role = standalone
netbios name = SEBJ-FREENAS-BACKUP
workgroup = WORKGROUP
security = user
pid directory = /var/run/samba
smb passwd file = /var/etc/private/smbpasswd
private dir = /var/etc/private
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
[Volume1]
path = /mnt/backup/Volume1
printable = no
veto files = /.snapshot/.windows/.mac/.zfs/
writeable = yes
browseable = yes
recycle:repository = .recycle/%U
recycle:keeptree = yes
recycle:versions = yes
recycle:touch = yes
recycle:directory_mode = 0777
recycle:subdir_mode = 0700
vfs objects = zfsacl aio_pthread audit extd_audit fake_perms netatalk streams_depot streams_xattr
hide dot files = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
zfsacl:acesort = dontcare
D
dlavigne
Guest
There has been 6 updates since that one. Please update to the latest STABLE and let us know if that fixes the issue.
TheFlow
Ok thanks, I updated to latest version. Same problem.
This is from samba4/smbd.log when trying to connect from Win7:
_______
[2015/02/23 14:46:22.584351, 2] ../source3/auth/auth.c:288(auth_check_ntlm_password)
check_ntlm_password: Authentication for user [veeambackup] -> [veeambackup] FAILED with error NT_STATUS_NO_SUCH_USER
[2015/02/23 14:46:22.585480, 2] ../source3/smbd/service.c:407(create_connection_session_info)
guest user (from session setup) not permitted to access this share (Volume1)
[2015/02/23 14:46:22.585506, 1] ../source3/smbd/service.c:550(make_connection_snum)
create_connection_session_info failed: NT_STATUS_ACCESS_DENIED
[2015/02/23 14:47:03.574434, 2] ../source3/smbd/server.c:419(remove_child_pid)
Could not find child 4134 -- ignoring
[2015/02/23 14:48:03.576438, 2] ../source3/smbd/server.c:419(remove_child_pid)
Could not find child 4180 -- ignoring
[2015/02/23 14:49:03.578415, 2] ../source3/smbd/server.c:419(remove_child_pid)
Could not find child 4209 -- ignoring
[2015/02/23 14:50:03.580425, 2] ../source3/smbd/server.c:419(remove_child_pid)
Could not find child 4239 -- ignoring
________
Do you know where to find information about the changes from 201501241715 to 201501301837? I've looked around but found nothing.
anodos
Sambassador
_______
________
Change logs can be found here: http://download.freenas.org/9.3/STABLE/
The fundamental problem is that you don't appear to have the user 'veeambackup' in samba's passdb file. "Authentication for user [veeambackup] -> [veeambackup] FAILED with error NT_STATUS_NO_SUCH_USER"
You can verify this by typing "pdbedit -L" you should see your user there. If you don't then, in the GUI change the password for your user "veeambackup". Then restart CIFS. This will force an update of credentials in samba's passdb.
TheFlow
Thanks for the link.
The user does exist in the passdb file. pdbedit -L gives:
veeambackup:1002:veeambackup
Anyway I did as you said but still unable to authenticate to the shares.
TheFlow
Just a wild guess, does NT_STATUS_NO_SUCH_USER have anything to do with domain accounts and why it can't find this user? I have no use for AD, just want the old local linux account to work with samba.
No such user means your username didn't exist for the given authentication mechanism (which *should* be local for you unless your server is misconfigured).
Access denied means your credentials were accepted but you didn't have permission to access that location.
Just to ask a stupid question, you aren't trying to create/change user accounts from the CLI are you? If so that's gonna be a major problem because doing those changes from the CLI *isn't* supposed to work.
anodos
Sambassador
Just an FYI. NetBIOS standard only allows for a 15 character name. Your smb4.conf indicates that you have 19 characters in your NetBIOS name. That may be causing some problems. Shorten the server's name then increase logging verbosity and reproduce the problem and attach the output here or enclose it in code tags.
TheFlow
Ok I shorted the Netbios name and now it works after setting new password / stopping cifs / revert to old password.
Thanks for all the help guys :)
anodos
Sambassador
That's interesting. For testing purposes: try changing your password to something different and simple (no special characters). If that doesn't work, try disabling all vfs objects except zfsacl.
Post the following:
  • getfacl output for share "getfacl /mnt/backup/Volume1"
  • Relevant log entries from winbind log. /var/log/samba/log.wb*
Nick McCloud
This thread saved my sanity. I went round the houses several times trying to get the Windows workstations in the office working until pdbedit -L told me that my login wasn't in the CIFS authentication database. Very unscientifically changed my password, stopped CIFS, changed password back, restarted CIFS and I was back on the list!
FreeNAS-9.3-STABLE-201503270027 - once the dust has settled on migrating the old file storage systems to FreeNAS I'll use one of the old servers to do a bit of testing / replay of events so I can be more useful. Big thanks to cyberjock for his presentation - took the edge off the learning curve in Jan/Feb.
