I'm having problems mounting CIFS shares in Rancher.
I create the YAML file and merge it into the config. Then, I reboot the Rancher VM. I can then browse the mount point. Then, I reboot the VM again to test the persistence and the share is not mounted. In the SAMBA log on my FreeNAS, I've noticed "receive_smb_raw_talloc failed for client ipv4:xxx.xxx.xxx.xxx:yyyyy read error = NT_STATUS_IO_TIMEOUT." with the IP address of my VM.
As far as I know, there should be no network issues between my filer and the VM, as they are on the same physical HW and it is very lightly used.
