I recently built a new FreeNAS server and created a Raid-Z2 volume and a dataset. When creating the volume and dataset I used the basic options page (not advanced options), this resulted in a volume which hat lz4 compression enabled and the dedup setting on inherit (from where do volumes inherit this setting)? The dataset inherited both options.
In order to speed up access to the share I disabled both compression and the dedup option on the volume and dataset explicitly. My question: Is this a problem (should I have created a new volume and dataset) or is it fine to change these options? I would prefer not to have to create a new volume and share but wanted to make sure before starting to copy data to the dataset...
