Spacemarine
- Jul 19, 2014
If I set the case sensitivity of a dataset from "sensitive" to "mixed" and immediately click the "edit options" icon again, I will show "sensitive" again. Am I missing something here? Do I have to reboot for the changes to take effect? Or is it a bug?
Also it seems that if I change it back to "mixed" a few times, then suddenly the share type changes from "windows" to "unix".
What is happening here?
I am using the newest version of freenas, 9.3.
Edit: I just checked: If I change the the permission type using the "key" symbol in the left coloumn, it will remain as "windows". If I use the right "wrench" symbol to change something, it will change back to "unix". Are those two different types of permission settings? Also under the left icon it is called "permission type", under the right icon it is called "share type". Now I am totally confused...
