We're looking at doing something like 7GB of physical RAM minimum to ensure we don't get "false positives". Most people aren't going to install 7GB of RAM just to avoid the warning. ;)
That is appearing in the console message log at the bottom (I saw someone recommend enabling that, I thought it a good idea - mind you it's not default)Sep 7 01:12:17 freenas smartd[18910]: Device: /dev/ada4, 360 Currently unreadable (pending) sectors
Sep 7 01:12:18 freenas smartd[18910]: Device: /dev/ada4, 45 Offline uncorrectable sectors
It is perfectly possible for SMART to assess a drive as passed while simultaneously having unreadable sectors.
# smartctl -a /dev/ada3
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family: Seagate Barracuda (SATA 3Gb/s, 4K Sectors)
Device Model: ST3000DM001-9YN166
Serial Number: xxxxxx
LU WWN Device Id: xxxxxxxxxxxxx
Firmware Version: CC4H
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sat Sep 6 10:21:51 2014 CDT
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 113) The previous self-test completed having
the read element of the test failed.
data collection: ( 575) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 322) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 117 091 006 Pre-fail Always - 156785408
3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 107
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 216
7 Seek_Error_Rate 0x000f 087 060 030 Pre-fail Always - 644730710
9 Power_On_Hours 0x0032 081 081 000 Old_age Always - 16658
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 21
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 099 099 099 Old_age Always FAILING_NOW 1
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 21475164165
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 067 045 045 Old_age Always In_the_past 33 (Min/Max 21/35)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 16
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 667
194 Temperature_Celsius 0x0022 033 055 000 Old_age Always - 33 (0 21 0 0 0)
197 Current_Pending_Sector 0x0012 100 001 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 001 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 128763119549804
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 71301624261542
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 76475582325877
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed: read failure 10% 16656 237578075
# 2 Short offline Interrupted (host reset) 10% 16647 -
# 3 Short offline Completed: read failure 10% 16642 236872309
# 4 Extended offline Completed: read failure 90% 16629 237578074
# 5 Short offline Completed: read failure 10% 16620 236043972
# 6 Short offline Completed: read failure 10% 16607 237578075
# 7 Short offline Completed: read failure 10% 16604 236872309
# 8 Short offline Completed: read failure 10% 16586 237577660
# 9 Short offline Completed: read failure 10% 16544 237578075
#10 Short offline Completed: read failure 10% 16527 237578075
#11 Short offline Completed: read failure 10% 16479 237578075
#12 Short offline Completed: read failure 10% 16477 237578075
#13 Extended offline Completed: read failure 90% 16465 237578075
#14 Short offline Completed: read failure 10% 16451 236043972
#15 Short offline Completed: read failure 10% 16448 237578075
#16 Short offline Completed: read failure 10% 16439 237578075
#17 Short offline Completed: read failure 10% 16437 237578075
#18 Extended offline Completed: read failure 90% 16406 237578075
#19 Short offline Completed: read failure 10% 16404 237578075
#20 Short offline Completed: read failure 10% 16402 237578075
#21 Short offline Completed: read failure 10% 16395 237578075
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Just to clarify, "unreadable sectors" I take it, are the same as "bad sectors"? If I were to format this in Windows, do a full chkdsk /r I'd end up with bad sectors marked or no?
In any case, if you have more than one or two (I go up to four, personally, as the maximum), the drive is not to be trusted as it will probably develop more bad sectors.
That's how I normally look at it too, it's indicative of long term issues even if it doesn't die instantly.For the record, I'm less forgiving than Eric.
If I get one bad sector? Drive comes straight out. Experience in my life (which, who knows, may be skewed) is the there is no such thing as "1 bad sector" there is only "0 bad sectors" or "precursor to entire drive failing within a few weeks".
I've never heard of conveyance?
1000 hours seems a bit excessive by any measurement.
