Can't Upgrade: CDROM not found/mounted on Vmware Workstation 7
jan.scott
I currently have FreeNAS 8.0 RELEASE installed as a Virtual machine on VMware Workstation 7 for testing purposes.
The issue is I'm trying to upgrade to 8.0.1 RC1, but it's not booting from the CDROM even though it is connected and selected to use the ISO file. The same process I use to install 8.0 initial, which worked.
I seems like it is not finding the CDROM or not mounting it. I don't know how to mount it or why it's not booting from it.
Any help would be great?
Thank you!
jan
