KazuyaDarklight
- May 8, 2019
TLDR; We had a mishap, we are trying to rebuild a pool, but the drives won't wipe and integrate.
My system was acting up this morning; trouble connecting to share, the UI was sluggish and didn't want to show a lot of UI elements but there were no disk/pool based msgs in the Notification drop down. So I rebooted. I have 2 pools, one is SSD, the other is HDDs. HDD came up fine, but the SSD pool was completely failed with no other info, it just had a big red Disconnect button next to it. The disks were all listed in the Disk area, they didn't have any errors, but their pool column said NA. After some failed attempts to figure out what had happened I tried the disconnect option on the pool and then tried to import the disks, still no go. So I moved on to just rebuilding the pool and adding the disks with the intent to pull all our data back in from backups. But while the UI lets me add the disks when it tries to wipe and format them it errors out with the following details.
Same if I try to just wipe them in the disk section.
While my immediate concern is getting the pool back up, hopefully in a trustworthy state, I would honestly love any help in trying to figure out what actually happened, though that may be a thread all its own. I'll also acknowledge it may be harder since we gave up and removed the pool, still, I'd be happy to try and pull logs etc. It would go a long way towards helping me feel like I can trust the system going forward.
Edited to fix some typos/readability.
Error: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 666, in do_create formatted_disks = await self.middleware.call('pool.format_disks', job, disks) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1241, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1198, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 56, in format_disks await asyncio_map(format_disk, disks.items(), limit=16) File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map return await asyncio.gather(*futures) File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 13, in func return await real_func(arg) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disk await self.middleware.call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1241, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1209, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1113, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/format.py", line 25, in format raise CallError(f'Failed to wipe disk {disk}: {job.error}') middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk da15: [EFAULT] Command gpart create -s gpt /dev/da15 failed (code 1): gpart: Input/output error
