hahndouglasf
- Jan 2, 2022
Olá a todos, espero que alguém possa me ajudar com esta questão (não possuo grande conhecimento com o sistema):
Cenário: Servidor Lenovo SR550 eram 3 HDs 4TB em pool (dois de 7200rpm e outro de 5400rpm) este disco de 5400rpm falhou então fomos substituir por outro de 7200rpm, mas estamos recebendo o erro:
*** Translation by Google Translator ***
Hi everyone, I hope someone can help me with this question (I don't have much knowledge of the system):
Scenario: Lenovo SR550 server was 3 4TB hard drives pooled (two 7200rpm and one 5400rpm) this 5400rpm drive failed so we should replace it with another 7200rpm but we are getting the error:
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/replace_disk.py", line 93, in replace
enc_disks = await self.middleware.call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1241, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1198, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 56, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 13, in func
return await real_func(arg)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disk
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1209, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1113, in run_in_executor
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/format.py", line 25, in format
raise CallError(f'Failed to wipe disk {disk}: {job.error}')
middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk da3: [EFAULT] Command dd if=/dev/zero of=/dev/da3p2 bs=1M count=32 failed (code 1):
dd: /dev/da3p2: Input/output error
1+0 records in
0+0 records out
0 bytes transferred in 0.003858 secs (0 bytes/sec)
await self.future
1+0 records in
0+0 records out
