SOLVED Can't load plugins truenas
remsjik
Hi everyone, Ive just installed truenas on an old pc, when trying to download additional plugins it will consistently keep on loading and prompting an error message after +/- 30secconds.
the only things I've done so far after the fresh install:
- created a user and group
- set up a storage pool
- enabled windows shares
- manually set an static IP
It my first time working with truenas (and networking in general) so please go easy on me:)
anyone got a clue?
Samuel Tai
Under Network->Global Configuration, make sure you have a default gateway set, and also a DNS server set. The error message indicates a DNS failure to resolve github.com. Usually this is because no DNS servers are configured.
remsjik
my god, I misstyped the default gateway. took me way longer than it should.
Thanks!
