Cant initiate iSCSI
Nicuz
Hi all!,
i have a problem when try initiate iSCSI service. The message is : The service could not be started.
in my "message" log´s say this:
Feb 4 18:55:51 freenas notifier: File "/usr/local/libexec/nas/generate_ctl_conf.py", line 64
Feb 4 18:55:51 freenas notifier: elif " " initiator.iscsi_target_initiator_auth_network:
Feb 4 18:55:51 freenas notifier: ^
Feb 4 18:55:51 freenas notifier: SyntaxError: invalid syntax
Feb 4 18:55:51 freenas notifier: ctld not running? (check /var/run/ctld.pid).
Feb 4 18:55:51 freenas root: /etc/rc.d/ctld: WARNING: /etc/ctl.conf is not readable.
Feb 4 18:55:51 freenas notifier: /etc/rc.d/ctld: WARNING: /etc/ctl.conf is not readable.
Feb 4 18:55:51 freenas root: /etc/rc.d/ctld: WARNING: failed precmd routine for ctld
Feb 4 18:55:51 freenas notifier: /etc/rc.d/ctld: WARNING: failed precmd routine for ctld
Thanks!
D
dlavigne
Guest
I'm pretty sure that bug was fixed in an update. Please use Boot -> Update to update the system to the latest STABLE.
I had the same issue with my original install, updated two or 3 times and it was fixed and its been working great since those updates
