Hey everyone,
I just setup a FreeNAS on my network and wanted to utilize ISCSI. I am using FreeNAS 9.3. I installed the updates from the GUI. I followed a guide on how to set it up, but the service fails to start. Looking at the logs I get the following error:
Anyone have any guidance?
-Z
Dec 6 14:07:54 freenas notifier: File "/usr/local/libexec/nas/generate_ctl_conf.py", line 64 Dec 6 14:07:54 freenas notifier: elif " " initiator.iscsi_target_initiator_auth_network: Dec 6 14:07:54 freenas notifier: ^ Dec 6 14:07:54 freenas notifier: SyntaxError: invalid syntax Dec 6 14:07:54 freenas notifier: ctld not running? (check /var/run/ctld.pid). Dec 6 14:07:54 freenas notifier: ctld not running? (check /var/run/ctld.pid). Dec 6 14:07:54 freenas root: /etc/rc.d/ctld: WARNING: /etc/ctl.conf is not readable. Dec 6 14:07:54 freenas notifier: /etc/rc.d/ctld: WARNING: /etc/ctl.conf is not readable. Dec 6 14:07:54 freenas root: /etc/rc.d/ctld: WARNING: failed precmd routine for ctld Dec 6 14:07:54 freenas notifier: /etc/rc.d/ctld: WARNING: failed precmd routine for ctld Dec 6 14:27:48 freenas notifier: File "/usr/local/libexec/nas/generate_ctl_conf.py", line 64 Dec 6 14:27:48 freenas notifier: elif " " initiator.iscsi_target_initiator_auth_network: Dec 6 14:27:48 freenas notifier: ^ Dec 6 14:27:48 freenas notifier: SyntaxError: invalid syntax Dec 6 14:27:48 freenas notifier: ctld not running? (check /var/run/ctld.pid). Dec 6 14:27:48 freenas notifier: ctld not running? (check /var/run/ctld.pid). Dec 6 14:27:48 freenas root: /etc/rc.d/ctld: WARNING: /etc/ctl.conf is not readable. Dec 6 14:27:48 freenas notifier: /etc/rc.d/ctld: WARNING: /etc/ctl.conf is not readable. Dec 6 14:27:48 freenas root: /etc/rc.d/ctld: WARNING: failed precmd routine for ctld Dec 6 14:27:48 freenas notifier: /etc/rc.d/ctld: WARNING: failed precmd routine for ctld
-Z
