SOLVED After update iSCSI does not work anymore?!
Tom7320
Hi there!
Today I upgraded to 9.3-stable. After that my iSCSI targets do not work anymore. When I try to start the service this happens in the log:
Dec  9 16:30:18 freenas notifier:   File "/usr/local/libexec/nas/generate_ctl_conf.py", line 64
Dec  9 16:30:18 freenas notifier:     elif " " initiator.iscsi_target_initiator_auth_network:
Dec  9 16:30:18 freenas notifier:                      ^
Dec  9 16:30:18 freenas notifier: SyntaxError: invalid syntax
Dec  9 16:30:18 freenas notifier: ctld not running? (check /var/run/ctld.pid).
Dec  9 16:30:18 freenas root: /etc/rc.d/ctld: WARNING: /etc/ctl.conf is not readable.
Dec  9 16:30:18 freenas notifier: /etc/rc.d/ctld: WARNING: /etc/ctl.conf is not readable.
Dec  9 16:30:18 freenas root: /etc/rc.d/ctld: WARNING: failed precmd routine for ctld
Dec  9 16:30:18 freenas notifier: /etc/rc.d/ctld: WARNING: failed precmd routine for ctld
Until the upgrade I had no problems. How can I fix that?
Thanks a lot!
Regards,
Thorsten
Tom7320
Oh! There seems to be an update available! Just a typo.... THX for reading anyway!!
didolgi
I have the same issue - I backed out back to 9.2.1.8-RELEASE until I could look at the problem in detail. The download link is pointing to the same ISO I downloaded yesterday. Am I missing something?
didolgi
Ah! Ok - I didn't realize it was already there in the built in update system. I rolled back to 9.2.1.8 when I got the error, planning to look at it in more detail later. Thanks!
bebbet
Hi, i can confirm the fix. I had the same troubles, with the update it is fixed.
