can't create a volume
SirMarty
This is my first time setting up a FreeNAS system and can't seem to get a volume created.
I have 6x500gb disks and intend to use Raid-Z2. The initial setup wizard only sees 5 drives (ada0,1,2,3,5). If I go to View Disks, all drives are there (I quick wiped them all) and when I use Volume Manager to create the volume, it sees all six drives, however, once everything is set and I click Add Volume, the screen refreshes and nothing shows under volumes. I went through the guide and it appears i'm creating the volume correctly, just not sure what i'm missing.
FreeNAS 9.2.10
Intel S3200SH
Xeon 4c
8gb ECC (4x2gb) Axiom (Nanya chips)
ada0 WDH1U5000N WD-WCASU2474368
ada1 JP1572FN2N19XK
ada2 WD-WCAS82322091
ada3 ST500DM002 W2A9JBWM
ada4 ST3500320A 9QM8EX84
ada5 ST3500418A 5VM1LQ3M
Spearfoot
He of the long foot
Hmmm... try deleting any existing volume(s) before creating a new one. The Volume Manager screenshot above shows that only a single drive was available when you tried to create the volume.
nojohnny101
Maybe also post the output of "zfs status" from the CLI and we'll see what you currently have going on.
SirMarty
I found the solution. I didn't notice the little message that said 'couldn't format ada4' I dban'd it (later learned the CLI way) and it worked now.
Spearfoot
He of the long foot
What does "dban'd" mean?
