[Solved] Cannot Replace a Bad Drive (i read and seach previously...), please help
Hi
I'm using freenas about 3 months without problems, rellay happy. I'm relative new to freenas but not to computers, but i cant do the right thing with this.
I have 2 raidz arrays. On one of them, it appeared a bad disk. I identified the disk, removed (raidz degraded), put new disk (it been used on another RaidZ). Then from GUI went to Storage -> View Disks -> Replace.
First error, it said something about this disk it was used on another raidz. Ok, i clean the disk with the following alternatives (reading other posts and internet) and try with 2 different disks:
- dd if=/dev/zero of=/dev/ada1 bs=512 count=1
- using diskpart on windows with the clean command
- low level format of the first 100Mb
When i tried to replace the disk the error was "Unable to GTP format disk ada7"... i dont know to do... please help.
The disks are WD20EARS Green 2tb (all of them) forced to 4kb, Freenas 8.0.2, and two raidz of 4 disks each one. One raidz is healty, the other degraded.
thanks in advance.
Hi
thanks in advance.
