Scott Crawford
- Jan 26, 2016
First off, my expertise is neither in FreeNAS nor networking but I do know computers fairly well so keep that in mind. I have had some weirdness and before going out and changing hardware I am to the point where I need advice.
I have a small and simple home network of a wireless router for part of my house and a wireless access point for the other. The router is wired to a desktop, the AP and my FreeNAS. The AP is used to connect to misc wireless devices, tablets, game consoles, etc. The freeNAS is a low power server based real machine (not VM) 16GB ECC memory, 6TB HD, etc. I built the FreeNAS to be simple file and media server using the latest 9.3 stable and the PlexMediaServer plugin residing in a jail, all patched up.
All of my devices between the router and AP can ping each other but one, the Plex running within the jail. The weirdness is any machine connected to the router, wired or wireless, can ping both the FreeNAS and Plex but from the AP the the devices can only ping the FreeNAS, the Plex is unreachable. The Plex can ping anything on the router but anything on the AP is unreachable. Scanning the subnet from the router side gives me 9 hits while from the AP side only 8 hits, with only the Plex missing. I have run the scans and pings from two different wireless devices and switching which wireless I am connected to.
Because I am having no other problems but contacting the jail I am rather confused. If I could not ping the FreeNAS, ping Plex, only one device was affected or problems between the router and AP I would have something to go on. To me it looks like something between the AP and the jail but I am at a loss what it might be. I am looking for suggestions to try or FreeNAS commands to run to help diagnose the issue.
dmesg output
Copyright (c) 1992-2014 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.3-RELEASE-p31 #0 r288272+81e2595: Mon Jan 18 10:48:44 PST 2016
root@build3.ixsystems.com:/tank/home/stable-builds/FN/objs/os-base/amd64/tank/home/stable-builds/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Atom(TM) CPU C2550 @ 2.40GHz (2400.06-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x406d8 Family = 0x6 Model = 0x4d Stepping = 8
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x43d8e3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,RDRAND>
AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
AMD Features2=0x101<LAHF,Prefetch>
Standard Extended Features=0x2282<TSCADJ,SMEP,ENHMOVSB>
TSC: P-state invariant, performance statistics
real memory = 17985175552 (17152 MB)
avail memory = 16490225664 (15726 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <INTEL TIANO >
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 2
cpu2 (AP): APIC ID: 4
cpu3 (AP): APIC ID: 6
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <ALASKA A M I > on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 450
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> mem 0xdf740000-0xdf75ffff irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> mem 0xdf720000-0xdf73ffff irq 20 at device 3.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> mem 0xdf500000-0xdf51ffff irq 22 at device 0.0 on pci2
pci3: <ACPI PCI bus> on pcib3
pcib4: <PCI-PCI bridge> irq 23 at device 1.0 on pci3
pci4: <PCI bus> on pcib4
ahci0: <Marvell 88SE9172 AHCI SATA controller> port 0xc040-0xc047,0xc030-0xc033,0xc020-0xc027,0xc010-0xc013,0xc000-0xc00f mem 0xdf410000-0xdf4101ff irq 23 at device 0.0 on pci4
ahci0: AHCI v1.00 with 2 6Gbps ports, Port Multiplier supported with FBS
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
pcib5: <PCI-PCI bridge> irq 23 at device 5.0 on pci3
pci5: <PCI bus> on pcib5
pcib6: <PCI-PCI bridge> irq 23 at device 0.0 on pci5
pci6: <PCI bus> on pcib6
vgapci0: <VGA-compatible display> port 0xb000-0xb07f mem 0xde000000-0xdeffffff,0xdf000000-0xdf01ffff irq 23 at device 0.0 on pci6
vgapci0: Boot video device
pcib7: <PCI-PCI bridge> irq 21 at device 7.0 on pci3
pci7: <PCI bus> on pcib7
igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xa000-0xa01f mem 0xdf300000-0xdf37ffff,0xdf380000-0xdf383fff irq 21 at device 0.0 on pci7
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: d0:50:99:78:d3:b9
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib8: <PCI-PCI bridge> irq 23 at device 9.0 on pci3
pci8: <PCI bus> on pcib8
igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x9000-0x901f mem 0xdf200000-0xdf27ffff,0xdf280000-0xdf283fff irq 23 at device 0.0 on pci8
igb1: Using MSIX interrupts with 5 vectors
igb1: Ethernet address: d0:50:99:78:d3:ba
igb1: Bound queue 0 to cpu 0
igb1: Bound queue 1 to cpu 1
igb1: Bound queue 2 to cpu 2
igb1: Bound queue 3 to cpu 3
pcib9: <ACPI PCI-PCI bridge> mem 0xdf700000-0xdf71ffff at device 4.0 on pci0
pci9: <ACPI PCI bus> on pcib9
ahci1: <Marvell 88SE9230 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0xdf610000-0xdf6107ff irq 23 at device 0.0 on pci9
ahci1: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
ahci1: quirks=0x900<NOBSYRES,ALTSIG>
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich6: <AHCI channel> at channel 4 on ahci1
ahcich7: <AHCI channel> at channel 5 on ahci1
ahcich8: <AHCI channel> at channel 6 on ahci1
ahcich9: <AHCI channel> at channel 7 on ahci1
ehci0: <Intel Avoton USB 2.0 controller> mem 0xdf763000-0xdf7633ff irq 23 at device 22.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
ahci2: <Intel Avoton AHCI SATA controller> port 0xe0d0-0xe0d7,0xe0c0-0xe0c3,0xe0b0-0xe0b7,0xe0a0-0xe0a3,0xe040-0xe05f mem 0xdf762000-0xdf7627ff irq 19 at device 23.0 on pci0
ahci2: AHCI v1.30 with 4 3Gbps ports, Port Multiplier not supported
ahcich10: <AHCI channel> at channel 0 on ahci2
ahcich11: <AHCI channel> at channel 1 on ahci2
ahcich12: <AHCI channel> at channel 2 on ahci2
ahcich13: <AHCI channel> at channel 3 on ahci2
ahci3: <Intel Avoton AHCI SATA controller> port 0xe090-0xe097,0xe080-0xe083,0xe070-0xe077,0xe060-0xe063,0xe020-0xe03f mem 0xdf761000-0xdf7617ff irq 19 at device 24.0 on pci0
ahci3: AHCI v1.30 with 2 6Gbps ports, Port Multiplier not supported
ahcich14: <AHCI channel> at channel 0 on ahci3
ahcich15: <AHCI channel> at channel 1 on ahci3
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
uart2: <16550 or compatible> port 0x248-0x24f irq 3 on acpi0
orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
usbus0: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
uhub0: 8 ports with 8 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub1: <vendor 0x8087 product 0x07db, class 9/0, rev 2.00/0.02, addr 2> on usbus0
uhub1: 4 ports with 4 removable, self powered
ugen0.3: <CPS> at usbus0
ugen0.4: <American Megatrends Inc.> at usbus0
uhub2: <7-port Hub> on usbus0
uhub2: 5 ports with 5 removable, self powered
ugen0.5: <American Megatrends Inc.> at usbus0
ukbd0: <Keyboard Interface> on usbus0
kbd2 at ukbd0
ums0: <Mouse Interface> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
ada0 at ahcich10 bus 0 scbus10 target 0 lun 0
ada0: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada0: Serial Number WD-WCC1T1258736
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad24
ada1 at ahcich13 bus 0 scbus13 target 0 lun 0
ada1: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada1: Serial Number WD-WCC1T0742646
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad30
ada2 at ahcich14 bus 0 scbus14 target 0 lun 0
ada2: <SanDisk SDSSDA120G U21010RL> ATA-9 SATA 3.x device
ada2: Serial Number 153587402538
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 512bytes)
ada2: Command Queueing enabled
ada2: 114473MB (234441648 512 byte sectors: 16H 63S/T 16383C)
ada2: Previously was known as ad32
pass0 at ahcich9 bus 0 scbus9 target 0 lun 0
pass0: <Marvell Console 1.01> Removable Processor SCSI-0 device
pass0: Serial Number HKDP221516WL
pass0: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
Timecounter "TSC-low" frequency 1200029004 Hz quality 1000
Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201601181840 []...
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
ipmi0: IPMI device rev. 1, firmware rev. 0.19, version 2.0
ipmi0: Number of channels 2
ipmi0: Attached watchdog
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: hardware
GEOM_ELI: Device ada1p1.eli created.
vboxdrv: fAsync=0 offMin=0x618 offMax=0x1308
bridge0: Ethernet address: 02:e9:d3:58:af:00
bridge0: link state changed to UP
igb0: promiscuous mode enabled
epair0a: Ethernet address: 02:4c:ee:00:07:0a
epair0b: Ethernet address: 02:4c:ee:00:08:0b
epair0a: link state changed to UP
epair0b: link state changed to UP
igb0: link state changed to DOWN
epair0a: promiscuous mode enabled
ng_ether_ifnet_arrival_event: can't re-name node epair0b
igb0: link state changed to UP
epair0a: link state changed to DOWN
epair0b: link state changed to DOWN
bridge0: link state changed to DOWN
igb0: promiscuous mode disabled
ifa_del_loopback_route: deletion failed
Freed UMA keg (udp_inpcb) was not empty (90 items). Lost 9 pages of memory.
Freed UMA keg (udpcb) was not empty (504 items). Lost 3 pages of memory.
Freed UMA keg (tcptw) was not empty (850 items). Lost 17 pages of memory.
Freed UMA keg (tcp_inpcb) was not empty (830 items). Lost 83 pages of memory.
Freed UMA keg (sackhole) was not empty (404 items). Lost 4 pages of memory.
Freed UMA keg (tcpcb) was not empty (84 items). Lost 21 pages of memory.
Freed UMA keg (ripcb) was not empty (40 items). Lost 4 pages of memory.
hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required
hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required
epair0a: Ethernet address: 02:42:ee:00:07:0a
epair0b: Ethernet address: 02:42:ee:00:08:0b
arp: 192.168.27.98 moved from 02:42:ee:00:07:0a to d0:50:99:78:d3:b9 on epair0b
epair0a: Ethernet address: 02:0b:c6:00:07:0a
epair0b: Ethernet address: 02:0b:c6:00:08:0b
Freed UMA keg (udp_inpcb) was not empty (60 items). Lost 6 pages of memory.
Freed UMA keg (tcptw) was not empty (200 items). Lost 4 pages of memory.
Freed UMA keg (tcp_inpcb) was not empty (90 items). Lost 9 pages of memory.
Freed UMA keg (tcpcb) was not empty (36 items). Lost 9 pages of memory.
Freed UMA keg (ripcb) was not empty (20 items). Lost 2 pages of memory.
epair0a: Ethernet address: 02:aa:84:00:07:0a
epair0b: Ethernet address: 02:aa:84:00:08:0b
Freed UMA keg (udp_inpcb) was not empty (50 items). Lost 5 pages of memory.
Freed UMA keg (tcp_inpcb) was not empty (70 items). Lost 7 pages of memory.
ipmi0: KCS: Reply address mismatch
ipmi0: KCS error: 5f
ifconfig output
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=400b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO>
ether d0:50:99:78:d3:b9
inet 192.168.27.98 netmask 0xffffff00 broadcast 192.168.27.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO>
ether d0:50:99:78:d3:ba
status: no carrier
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
ether 02:e9:d3:58:af:00
nd6 options=1<PERFORMNUD>
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000
member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:aa:84:00:07:0a
status: active
