freenas violent reboot
junior
Hello, so I've got my first real problem since I use freenas.
I had a violent reboot. So I checked the logs and I've got a lot of error related to network.
Copyright (c) 1992-2014 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.3-RELEASE-p13 #0 r281084+3bda974: Tue May 12 21:03:11 PDT 2015
root@build3.ixsystems.com:/tank/home/jkh/build/FN/objs/os-base/amd64/tank/home/jkh/build/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Atom(TM) CPU C2550 @ 2.40GHz (2400.15-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x406d8 Family = 0x6 Model = 0x4d Stepping = 8
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x43d8e3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,RDRAND>
AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
AMD Features2=0x101<LAHF,Prefetch>
Standard Extended Features=0x2282<TSCADJ,SMEP,ENHMOVSB>
TSC: P-state invariant, performance statistics
real memory = 36507222016 (34816 MB)
avail memory = 33073143808 (31541 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <INTEL TIANO >
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 2
cpu2 (AP): APIC ID: 4
cpu3 (AP): APIC ID: 6
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ispfw: registered firmware <isp_1040>
ispfw: registered firmware <isp_1040_it>
ispfw: registered firmware <isp_1080>
ispfw: registered firmware <isp_1080_it>
ispfw: registered firmware <isp_12160>
ispfw: registered firmware <isp_12160_it>
ispfw: registered firmware <isp_2100>
ispfw: registered firmware <isp_2200>
ispfw: registered firmware <isp_2300>
ispfw: registered firmware <isp_2322>
ispfw: registered firmware <isp_2400>
ispfw: registered firmware <isp_2400_multi>
ispfw: registered firmware <isp_2500>
ispfw: registered firmware <isp_2500_multi>
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <ALASKA A M I > on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 450
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> mem 0xffff40000-0xffff5ffff irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xd000-0xd0ff mem 0xdf700000-0xdf700fff,0xfffe00000-0xfffe03fff irq 16 at device 0.0 on pci1
re0: Using 1 MSI-X message
re0: Chip rev. 0x2c000000
re0: MAC rev. 0x00200000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 64:66:b3:02:3c:91
pcib2: <ACPI PCI-PCI bridge> mem 0xffff20000-0xffff3ffff irq 20 at device 3.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> mem 0xdf500000-0xdf51ffff irq 22 at device 0.0 on pci2
pci3: <ACPI PCI bus> on pcib3
pcib4: <PCI-PCI bridge> irq 23 at device 1.0 on pci3
pci4: <PCI bus> on pcib4
ahci0: <Marvell 88SE9172 AHCI SATA controller> port 0xb040-0xb047,0xb030-0xb033,0xb020-0xb027,0xb010-0xb013,0xb000-0xb00f mem 0xdf410000-0xdf4101ff irq 23 at device 0.0 on pci4
ahci0: AHCI v1.00 with 2 6Gbps ports, Port Multiplier supported with FBS
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
pcib5: <PCI-PCI bridge> irq 23 at device 5.0 on pci3
pci5: <PCI bus> on pcib5
pcib6: <PCI-PCI bridge> irq 23 at device 0.0 on pci5
pci6: <PCI bus> on pcib6
vgapci0: <VGA-compatible display> port 0xa000-0xa07f mem 0xde000000-0xdeffffff,0xdf000000-0xdf01ffff irq 23 at device 0.0 on pci6
vgapci0: Boot video device
pcib7: <PCI-PCI bridge> irq 21 at device 7.0 on pci3
pci7: <PCI bus> on pcib7
igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x9000-0x901f mem 0xdf300000-0xdf37ffff,0xdf380000-0xdf383fff irq 21 at device 0.0 on pci7
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: d0:50:99:0a:63:05
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib8: <PCI-PCI bridge> irq 23 at device 9.0 on pci3
pci8: <PCI bus> on pcib8
igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x8000-0x801f mem 0xdf200000-0xdf27ffff,0xdf280000-0xdf283fff irq 23 at device 0.0 on pci8
igb1: Using MSIX interrupts with 5 vectors
igb1: Ethernet address: d0:50:99:0a:63:06
igb1: Bound queue 0 to cpu 0
igb1: Bound queue 1 to cpu 1
igb1: Bound queue 2 to cpu 2
igb1: Bound queue 3 to cpu 3
pcib9: <ACPI PCI-PCI bridge> mem 0xffff00000-0xffff1ffff at device 4.0 on pci0
pci9: <ACPI PCI bus> on pcib9
ahci1: <Marvell 88SE9230 AHCI SATA controller> port 0xc050-0xc057,0xc040-0xc043,0xc030-0xc037,0xc020-0xc023,0xc000-0xc01f mem 0xdf610000-0xdf6107ff irq 23 at device 0.0 on pci9
ahci1: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
ahci1: quirks=0x900<NOBSYRES,ALTSIG>
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich6: <AHCI channel> at channel 4 on ahci1
ahcich7: <AHCI channel> at channel 5 on ahci1
ahcich8: <AHCI channel> at channel 6 on ahci1
ahcich9: <AHCI channel> at channel 7 on ahci1
ehci0: <Intel Avoton USB 2.0 controller> mem 0xdf803000-0xdf8033ff irq 23 at device 22.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
ahci2: <Intel Avoton AHCI SATA controller> port 0xe0d0-0xe0d7,0xe0c0-0xe0c3,0xe0b0-0xe0b7,0xe0a0-0xe0a3,0xe040-0xe05f mem 0xdf802000-0xdf8027ff irq 19 at device 23.0 on pci0
ahci2: AHCI v1.30 with 4 3Gbps ports, Port Multiplier not supported
ahcich10: <AHCI channel> at channel 0 on ahci2
ahcich11: <AHCI channel> at channel 1 on ahci2
ahcich12: <AHCI channel> at channel 2 on ahci2
ahcich13: <AHCI channel> at channel 3 on ahci2
ahci3: <Intel Avoton AHCI SATA controller> port 0xe090-0xe097,0xe080-0xe083,0xe070-0xe077,0xe060-0xe063,0xe020-0xe03f mem 0xdf801000-0xdf8017ff irq 19 at device 24.0 on pci0
ahci3: AHCI v1.30 with 2 6Gbps ports, Port Multiplier not supported
ahcich14: <AHCI channel> at channel 0 on ahci3
ahcich15: <AHCI channel> at channel 1 on ahci3
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
uart2: <16550 or compatible> port 0x248-0x24f irq 3 on acpi0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
fdc0: <Enhanced floppy controller> at port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on isa0
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
usbus0: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
uhub0: 8 ports with 8 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub1: <vendor 0x8087 product 0x07db, class 9/0, rev 2.00/0.02, addr 2> on usbus0
uhub1: 4 ports with 4 removable, self powered
ugen0.3: <American Power Conversion> at usbus0
ugen0.4: <vendor 0x0930> at usbus0
umass0: <vendor 0x0930 USB Flash Memory, class 0/0, rev 2.00/1.10, addr 4> on usbus0
umass0: SCSI over Bulk-Only; quirks = 0x4000
umass0:17:0:-1: Attached to scbus17
ugen0.5: <American Megatrends Inc.> at usbus0
uhub2: <7-port Hub> on usbus0
uhub2: 5 ports with 5 removable, self powered
ugen0.6: <American Megatrends Inc.> at usbus0
ukbd0: <Keyboard Interface> on usbus0
kbd2 at ukbd0
ums0: <Mouse Interface> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9da0 at umass-sim0 bus 0 scbus17 target 0 lun 0
da0: < USB Flash Memory PMAP> Removable Direct Access SCSI-0 device
da0: Serial Number 001D92AF7F80B8B11000006E
da0: 40.000MB/s transfers
da0: 15320MB (31375360 512 byte sectors: 255H 63S/T 1953C)
da0: quirks=0x2<NO_6_BYTE>
SATA 3.x device
ada0: Serial Number WD-WMC1T2242382
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada1: Serial Number WD-WMC1T2173960
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada2: Serial Number WD-WMC1T2201844
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada2: quirks=0x1<4K>
ada2: Previously was known as ad8
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada3: Serial Number WD-WMC1T2221936
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada3: quirks=0x1<4K>
ada3: Previously was known as ad10
ada4 at ahcich4 bus 0 scbus4 target 0 lun 0
ada4: <WDC WD30EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device
ada4: Serial Number WD-WMC4N2711881
ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada4: quirks=0x1<4K>
ada4: Previously was known as ad12
pass5 at ahcich9 bus 0 scbus9 target 0 lun 0
pass5: <Marvell Console 1.01> Removable Processor SCSI-0 device
pass5: Serial Number HKDP221516WL
pass5: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
Timecounter "TSC-low" frequency 1200076896 Hz quality 1000
Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201505130355 []...
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
ipmi0: IPMI device rev. 1, firmware rev. 0.19, version 2.0
ipmi0: Number of channels 2
ipmi0: Attached watchdog
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: hardware
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Device ada4p1.eli created.
nfsd: can't register svc name
vboxdrv: fAsync=0 offMin=0x5e8 offMax=0xf48
bridge0: Ethernet address: 02:60:a1:91:2e:00
bridge0: link state changed to UP
re0: promiscuous mode enabled
epair0a: Ethernet address: 02:41:9c:00:09:0a
epair0b: Ethernet address: 02:41:9c:00:0a:0b
epair0a: link state changed to UP
epair0b: link state changed to UP
epair0a: promiscuous mode enabled
re0: link state changed to DOWN
ng_ether_ifnet_arrival_event: can't re-name node epair0b
re0: link state changed to UP
epair1a: Ethernet address: 02:a6:69:00:0a:0a
epair1b: Ethernet address: 02:a6:69:00:0b:0b
epair1a: link state changed to UP
epair1b: link state changed to UP
epair1a: promiscuous mode enabled
ng_ether_ifnet_arrival_event: can't re-name node epair1b
epair2a: Ethernet address: 02:61:56:00:0b:0a
epair2b: Ethernet address: 02:61:56:00:0c:0b
epair2a: link state changed to UP
epair2b: link state changed to UP
epair2a: promiscuous mode enabled
ng_ether_ifnet_arrival_event: can't re-name node epair2b
epair3a: Ethernet address: 02:03:0b:00:0c:0a
epair3b: Ethernet address: 02:03:0b:00:0d:0b
epair3a: link state changed to UP
epair3b: link state changed to UP
epair3a: promiscuous mode enabled
ng_ether_ifnet_arrival_event: can't re-name node epair3b
epair4a: Ethernet address: 02:cb:a2:00:0d:0a
epair4b: Ethernet address: 02:cb:a2:00:0e:0b
epair4a: link state changed to UP
epair4b: link state changed to UP
epair4a: promiscuous mode enabled
ng_ether_ifnet_arrival_event: can't re-name node epair4b
epair5a: Ethernet address: 02:cb:b3:00:0e:0a
epair5b: Ethernet address: 02:cb:b3:00:0f:0b
epair5a: link state changed to UP
epair5b: link state changed to UP
epair5a: promiscuous mode enabled
ng_ether_ifnet_arrival_event: can't re-name node epair5b
epair6a: Ethernet address: 02:55:ba:00:0f:0a
epair6b: Ethernet address: 02:55:ba:00:10:0b
epair6a: link state changed to UP
epair6b: link state changed to UP
epair6a: promiscuous mode enabled
ng_ether_ifnet_arrival_event: can't re-name node epair6b
epair3a: link state changed to DOWN
epair3b: link state changed to DOWN
epair0a: link state changed to DOWN
epair0b: link state changed to DOWN
ifa_del_loopback_route: deletion failed
Freed UMA keg (udp_inpcb) was not empty (40 items). Lost 4 pages of memory.
Freed UMA keg (udpcb) was not empty (504 items). Lost 3 pages of memory.
Freed UMA keg (tcptw) was not empty (100 items). Lost 2 pages of memory.
Freed UMA keg (tcp_inpcb) was not empty (40 items). Lost 4 pages of memory.
Freed UMA keg (tcpcb) was not empty (16 items). Lost 4 pages of memory.
Freed UMA keg (ripcb) was not empty (10 items). Lost 1 pages of memory.
hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required
hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required
Freed UMA keg (tcpcb) was not empty (24 items). Lost 6 pages of memory.
epair1a: link state changed to DOWN
epair1b: link state changed to DOWN
The event log of my motherboard shows a lot of NMI errors with "software" related.
It was with Freenas-Stable-201506042008.
I rebooted and now with
Freenas-Stable-201505130355, the event log is quiet.
What steps should I perform to find the culprit ?
Is it network driver related ?
Thanks.
jgreco
Resident Grinch
There's a link at the top of the page in green for bug reporting. The developers don't usually participate in the forums, and unless someone else here has seen a similar problem, you're not likely to get a useful result posting here (sorry). That doesn't mean we're not interested, just that we don't know.
junior
"Uh oh..." -> yeah I know but that one I can remove, I will try next week.
I've not really the time to do some tests right know, it seems stable at the time.
Thanks.
Thanks.
So that should have been your cue to not buy it. Since you can't remove it, if the Realtek driver is unstable you are basically fscked.
If I got a nickel for every time someone claimed it was stable and then became unstable, I'd be rich. Even one of our own mods had a motherboard with a Realtek and can't use it anymore because he "found out the hard way" it wasn't stable.
gpsguy
Active Member
To be fair to the OP, he does have 2 Intel NIC's in it. If he's using the Realtek, I'd remove and/or disable it and use one of the Intel's instead.
junior
gpsguy, thanks for noticing ;)
I removed the realtek, but nothing changed. I had to reinstalled the whole thing.
We'll see.
Thanks.
DrKK
FreeNAS Generalissimo
If his boot/system pool got corrupted (he does not mention any redundancy of that), then I can easily imagine what he was seeing.
junior
I don't have redundancy. I'm looking for a solution to put two usb key inside my tower. I only have two usb ports available at the moment.
One for the usb boot key and the other for the ups.
survive
Behold the Wumpus
Hi guys,
In Ericlowe's Amazon link this:
http://www.amazon.com/dp/B002GNU2V6/?tag=ozlp-20
was in the "Customers Who Bought This Item Also Bought" section below.
Pair that up with a couple of SanDisk Fit USB key & you should be set.
-Will
junior
yeah, when I will have the time. I've to put a nice plug too. Rearrange the cables ...
