STREBLO
- Oct 23, 2015
I'm having a bit of trouble interpreting my security output and there are couple of things specifically that I was worried about. How do I know what exactly is a problem? Do you always get security output, or only when there is a problem?
Specifically I was worried about the following messages:
and
Here is my full report:
> wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
and
> Freed UMA keg (udp_inpcb) was not empty (80 items). Lost 8 pages of memory. > Freed UMA keg (udpcb) was not empty (1008 items). Lost 6 pages of memory. > Freed UMA keg (tcp_inpcb) was not empty (70 items). Lost 7 pages of memory. > Freed UMA keg (tcpcb) was not empty (28 items). Lost 7 pages of memory. > Freed UMA keg (ripcb) was not empty (20 items). Lost 2 pages of memory. > hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required > hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required > igb0: link state changed to UP > pid 1896 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Lilan.local changes in mounted filesystems: 1d0 < /mnt/tank/data/bacula/postgres /mnt/tank/jails/bacula-server/mnt/postgres nullfs rw 0 0 3d1 < devfs /mnt/tank/jails/bacula-server/dev devfs rw,multilabel 0 0 6d3 < procfs /mnt/tank/jails/bacula-server/proc procfs rw 0 0 21,23d17 < tank/data /mnt/tank/data zfs rw,nfsv4acls 0 0 < tank/data/bacula /mnt/tank/data/bacula zfs rw,nfsv4acls 0 0 < tank/data/bacula/postgres /mnt/tank/data/bacula/postgres zfs rw,nfsv4acls 0 0 28d21 < tank/jails/bacula-server /mnt/tank/jails/bacula-server zfs rw,nfsv4acls 0 0 Lilan.local kernel log messages: > epair0a: link state changed to DOWN > epair0b: link state changed to DOWN > igb0: link state changed to DOWN > bridge0: link state changed to DOWN > igb0: promiscuous mode disabled > ifa_del_loopback_route: deletion failed > Freed UMA keg (udp_inpcb) was not empty (80 items). Lost 8 pages of memory. > Freed UMA keg (udpcb) was not empty (1008 items). Lost 6 pages of memory. > Freed UMA keg (tcp_inpcb) was not empty (70 items). Lost 7 pages of memory. > Freed UMA keg (tcpcb) was not empty (28 items). Lost 7 pages of memory. > Freed UMA keg (ripcb) was not empty (20 items). Lost 2 pages of memory. > hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required > hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required > igb0: link state changed to UP > pid 1896 (syslog-ng), uid 0: exited on signal 6 (core dumped) > Waiting (max 60 seconds) for system process `vnlru' to stop...done > Waiting (max 60 seconds) for system process `bufdaemon' to stop...done > Waiting (max 60 seconds) for system process `syncer' to stop... > Syncing disks, vnodes remaining...0 0 0 0 0 0 done > All buffers synced. > Copyright (c) 1992-2014 The FreeBSD Project. > Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 > The Regents of the University of California. All rights reserved. > FreeBSD is a registered trademark of The FreeBSD Foundation. > FreeBSD 9.3-RELEASE-p28 #0 r288272+a23e16d: Wed Nov 4 00:20:46 PST 2015 > root@build3.ixsystems.com:/tank/home/stable-builds/FN/objs/os-base/amd64/tank/home/stable-builds/FN/FreeBSD/src/sys/FREENAS.amd64 amd64 > gcc version 4.2.1 20070831 patched [FreeBSD] > CPU: Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz (3400.07-MHz K8-class CPU) > Origin = "GenuineIntel" Id = 0x306c3 Family = 0x6 Model = 0x3c Stepping = 3 > Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE> > Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,<b11>,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND> > AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM> > AMD Features2=0x21<LAHF,ABM> > Standard Extended Features=0x27ab<GSFSBASE,TSCADJ,SMEP,ENHMOVSB,INVPCID> > TSC: P-state invariant, performance statistics > real memory = 34896609280 (33280 MB) > avail memory = 33124106240 (31589 MB) > Event timer "LAPIC" quality 600 > ACPI APIC Table: <SUPERM SMCI--MB> > FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs > FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads > cpu0 (BSP): APIC ID: 0 > cpu1 (AP): APIC ID: 1 > cpu2 (AP): APIC ID: 2 > cpu3 (AP): APIC ID: 3 > cpu4 (AP): APIC ID: 4 > cpu5 (AP): APIC ID: 5 > cpu6 (AP): APIC ID: 6 > cpu7 (AP): APIC ID: 7 > WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. > ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325) > ioapic0 <Version 2.0> irqs 0-23 on motherboard > ispfw: registered firmware <isp_1040> > ispfw: registered firmware <isp_1040_it> > ispfw: registered firmware <isp_1080> > ispfw: registered firmware <isp_1080_it> > ispfw: registered firmware <isp_12160> > ispfw: registered firmware <isp_12160_it> > ispfw: registered firmware <isp_2100> > ispfw: registered firmware <isp_2200> > ispfw: registered firmware <isp_2300> > ispfw: registered firmware <isp_2322> > ispfw: registered firmware <isp_2400> > ispfw: registered firmware <isp_2400_multi> > ispfw: registered firmware <isp_2500> > ispfw: registered firmware <isp_2500_multi> > kbd1 at kbdmux0 > cryptosoft0: <software crypto> on motherboard > aesni0: <AES-CBC,AES-XTS> on motherboard > padlock0: No ACE support. > acpi0: <SUPERM SMCI--MB> on motherboard > acpi0: Power Button (fixed) > cpu0: <ACPI CPU> on acpi0 > cpu1: <ACPI CPU> on acpi0 > cpu2: <ACPI CPU> on acpi0 > cpu3: <ACPI CPU> on acpi0 > cpu4: <ACPI CPU> on acpi0 > cpu5: <ACPI CPU> on acpi0 > cpu6: <ACPI CPU> on acpi0 > cpu7: <ACPI CPU> on acpi0 > hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 > Timecounter "HPET" frequency 14318180 Hz quality 950 > Event timer "HPET" frequency 14318180 Hz quality 550 > atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0 > Event timer "RTC" frequency 32768 Hz quality 0 > attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0 > Timecounter "i8254" frequency 1193182 Hz quality 0 > Event timer "i8254" frequency 1193182 Hz quality 100 > Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 > acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0 > pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 > pci0: <ACPI PCI bus> on pcib0 > pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0 > pci1: <ACPI PCI bus> on pcib1 > pcib2: <ACPI PCI-PCI bridge> irq 16 at device 1.1 on pci0 > pci2: <ACPI PCI bus> on pcib2 > mps0: <Avago Technologies (LSI) SAS2308> port 0xe000-0xe0ff mem 0xf7240000-0xf724ffff,0xf7200000-0xf723ffff irq 17 at device 0.0 on pci2 > mps0: Firmware: 20.00.04.00, Driver: 20.00.00.00-fbsd > mps0: IOCCapabilities: 5285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> > pci0: <serial bus, USB> at device 20.0 (no driver attached) > ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7514000-0xf75143ff irq 16 at device 26.0 on pci0 > usbus0: EHCI version 1.0 > usbus0 on ehci0 > pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0 > pci3: <ACPI PCI bus> on pcib3 > pcib4: <ACPI PCI-PCI bridge> at device 0.0 on pci3 > pci4: <ACPI PCI bus> on pcib4 > vgapci0: <VGA-compatible display> port 0xd000-0xd07f mem 0xf6000000-0xf6ffffff,0xf7000000-0xf701ffff irq 16 at device 0.0 on pci4 > vgapci0: Boot video device > pcib5: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0 > pci5: <ACPI PCI bus> on pcib5 > igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xc000-0xc01f mem 0xf7400000-0xf747ffff,0xf7480000-0xf7483fff irq 18 at device 0.0 on pci5 > igb0: Using MSIX interrupts with 5 vectors > igb0: Ethernet address: 0c:c4:7a:69:69:94 > igb0: Bound queue 0 to cpu 0 > igb0: Bound queue 1 to cpu 1 > igb0: Bound queue 2 to cpu 2 > igb0: Bound queue 3 to cpu 3 > pcib6: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0 > pci6: <ACPI PCI bus> on pcib6 > igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xb000-0xb01f mem 0xf7300000-0xf737ffff,0xf7380000-0xf7383fff irq 19 at device 0.0 on pci6 > igb1: Using MSIX interrupts with 5 vectors > igb1: Ethernet address: 0c:c4:7a:69:69:95 > igb1: Bound queue 0 to cpu 4 > igb1: Bound queue 1 to cpu 5 > igb1: Bound queue 2 to cpu 6 > igb1: Bound queue 3 to cpu 7 > ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7513000-0xf75133ff irq 22 at device 29.0 on pci0 > usbus1: EHCI version 1.0 > usbus1 on ehci1 > isab0: <PCI-ISA bridge> at device 31.0 on pci0 > isa0: <ISA bus> on isab0 > ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf050-0xf057,0xf040-0xf043,0xf030-0xf037,0xf020-0xf023,0xf000-0xf01f mem 0xf7512000-0xf75127ff irq 19 at device 31.2 on pci0 > ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported > ahcich0: <AHCI channel> at channel 0 on ahci0 > ahcich1: <AHCI channel> at channel 1 on ahci0 > ahcich2: <AHCI channel> at channel 2 on ahci0 > ahcich3: <AHCI channel> at channel 3 on ahci0 > ahcich4: <AHCI channel> at channel 4 on ahci0 > ahcich5: <AHCI channel> at channel 5 on ahci0 > acpi_button0: <Sleep Button> on acpi0 > acpi_button1: <Power Button> on acpi0 > acpi_tz0: <Thermal Zone> on acpi0 > acpi_tz1: <Thermal Zone> on acpi0 > uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 > uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0 > uart2: <16550 or compatible> port 0x3e8-0x3ef irq 5 on acpi0 > orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff on isa0 > sc0: <System console> at flags 0x100 on isa0 > sc0: CGA <16 virtual consoles, flags=0x300> > vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0 > wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this. > coretemp0: <CPU On-Die Thermal Sensors> on cpu0 > est0: <Enhanced SpeedStep Frequency Control> on cpu0 > coretemp1: <CPU On-Die Thermal Sensors> on cpu1 > est1: <Enhanced SpeedStep Frequency Control> on cpu1 > coretemp2: <CPU On-Die Thermal Sensors> on cpu2 > est2: <Enhanced SpeedStep Frequency Control> on cpu2 > coretemp3: <CPU On-Die Thermal Sensors> on cpu3 > est3: <Enhanced SpeedStep Frequency Control> on cpu3 > coretemp4: <CPU On-Die Thermal Sensors> on cpu4 > est4: <Enhanced SpeedStep Frequency Control> on cpu4 > coretemp5: <CPU On-Die Thermal Sensors> on cpu5 > est5: <Enhanced SpeedStep Frequency Control> on cpu5 > coretemp6: <CPU On-Die Thermal Sensors> on cpu6 > est6: <Enhanced SpeedStep Frequency Control> on cpu6 > coretemp7: <CPU On-Die Thermal Sensors> on cpu7 > est7: <Enhanced SpeedStep Frequency Control> on cpu7 > ZFS filesystem version: 5 > ZFS storage pool version: features support (5000) > Timecounters tick every 1.000 msec > ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled > usbus0: 480Mbps High Speed USB v2.0 > usbus1: 480Mbps High Speed USB v2.0 > ugen0.1: <Intel> at usbus0 > uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0 > ugen1.1: <Intel> at usbus1 > uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 > mps0: SAS Address for SATA device = 4868483ee1c0c380 > mps0: SAS Address from SATA device = 4868483ee1c0c380 > mps0: SAS Address for SATA device = 4868483ee1c6cf7e > mps0: SAS Address from SATA device = 4868483ee1c6cf7e > mps0: SAS Address for SATA device = 4868483ee1e6c36b > mps0: SAS Address from SATA device = 4868483ee1e6c36b > mps0: SAS Address for SATA device = 4868483ee1c3d372 > mps0: SAS Address from SATA device = 4868483ee1c3d372 > mps0: SAS Address for SATA device = 4868483ee1c4cd71 > mps0: SAS Address from SATA device = 4868483ee1c4cd71 > mps0: SAS Address for SATA device = 4868483ee1c1b380 > mps0: SAS Address from SATA device = 4868483ee1c1b380 > uhub0: 2 ports with 2 removable, self powered > uhub1: 2 ports with 2 removable, self powered > ugen0.2: <vendor 0x8087> at usbus0 > uhub2: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus0 > ugen1.2: <vendor 0x8087> at usbus1 > uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus1 > uhub2: 4 ports with 4 removable, self powered > uhub3: 6 ports with 6 removable, self powered > ugen0.3: <vendor 0x0557> at usbus0 > uhub4: <vendor 0x0557 product 0x7000, class 9/0, rev 2.00/0.00, addr 3> on usbus0 > uhub4: 4 ports with 3 removable, self powered > ugen1.3: <vendor 0x0764> at usbus1 > ugen0.4: <vendor 0x0557> at usbus0 > ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0 > kbd0 at ukbd0 > ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0 > ums0: 3 buttons and [XYZ] coordinates ID=0 > da0 at mps0 bus 0 scbus0 target 0 lun 0 > da0: <ATA WDC WD60EFRX-68M 0A82> Fixed Direct Access SCSI-6 device > da0: Serial Number WD-WX91D65350FE > da0: 600.000MB/s transfers > da0: Command Queueing enabled > da0: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) > da0: quirks=0x8<4K> > da1 at mps0 bus 0 scbus0 target 1 lun 0 > da1: <ATA WDC WD60EFRX-68M 0A82> Fixed Direct Access SCSI-6 device > da1: Serial Number WD-WX91D65356RC > da1: 600.000MB/s transfers > da1: Command Queueing enabled > da1: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) > da1: quirks=0x8<4K> > da2 at mps0 bus 0 scbus0 target 2 lun 0 > da2: <ATA WDC WD60EFRX-68M 0A82> Fixed Direct Access SCSI-6 device > da2: Serial Number WD-WX91D6535VF0 > da2: 600.000MB/s transfers > da2: Command Queueing enabled > da2: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) > da2: quirks=0x8<4K> > da3 at mps0 bus 0 scbus0 target 3 lun 0 > da3: <ATA WDC WD60EFRX-68M 0A82> Fixed Direct Access SCSI-6 device > da3: Serial Number WD-WX91D65353V7 > da3: 600.000MB/s transfers > da3: Command Queueing enabled > da3: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) > da3: quirks=0x8<4K> > da4 at mps0 bus 0 scbus0 target 4 lun 0 > da4: <ATA WDC WD60EFRX-68M 0A82> Fixed Direct Access SCSI-6 device > da4: Serial Number WD-WX91D65354P6 > da4: 600.000MB/s transfers > da4: Command Queueing enabled > da4: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) > da4: quirks=0x8<4K> > da5 at mps0 bus 0 scbus0 target 5 lun 0 > da5: <ATA WDC WD60EFRX-68M 0A82> Fixed Direct Access SCSI-6 device > da5: Serial Number WD-WX91D653516E > da5: 600.000MB/s transfers > da5: Command Queueing enabled > da5: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) > da5: quirks=0x8<4K> > ada0 at ahcich0 bus 0 scbus1 target 0 lun 0 > ada0: <SATA SSD S9FM02.1> ATA-10 SATA 3.x device > ada0: Serial Number B4500757052400104657 > ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) > ada0: Command Queueing enabled > ada0: 30533MB (62533296 512 byte sectors: 16H 63S/T 16383C) > ada0: Previously was known as ad4 > ada1 at ahcich1 bus 0 scbus2 target 0 lun 0 > ada1: <SATA SSD S9FM02.1> ATA-10 SATA 3.x device > ada1: Serial Number AF340757052400153834 > ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) > ada1: Command Queueing enabled > ada1: 30533MB (62533296 512 byte sectors: 16H 63S/T 16383C) > ada1: Previously was known as ad6 > SMP: AP CPU #1 Launched! > SMP: AP CPU #7 Launched! > SMP: AP CPU #5 Launched! > SMP: AP CPU #2 Launched! > SMP: AP CPU #4 Launched! > SMP: AP CPU #3 Launched! > SMP: AP CPU #6 Launched! > Timecounter "TSC-low" frequency 1700036738 Hz quality 1000 > Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201511040813 []... > GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) > ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0 > ipmi0: KCS mode found at io 0xca2 on acpi > ipmi0: IPMI device rev. 1, firmware rev. 1.92, version 2.0 > ipmi0: Number of channels 2 > ipmi0: Attached watchdog > ipmi1: <IPMI System Interface> on isa0 > device_attach: ipmi1 attach returned 16 > wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this. > wbwd0: HEFRAS and EFER do not align: EFER 0x4e DevID 0x00 DevRev 0x00 CR26 0x00 > GEOM_ELI: Device da0p1.eli created. > GEOM_ELI: Encryption: AES-XTS 256 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device da1p1.eli created. > GEOM_ELI: Encryption: AES-XTS 256 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device da2p1.eli created. > GEOM_ELI: Encryption: AES-XTS 256 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device da3p1.eli created. > GEOM_ELI: Encryption: AES-XTS 256 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device da4p1.eli created. > GEOM_ELI: Encryption: AES-XTS 256 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device da5p1.eli created. > GEOM_ELI: Encryption: AES-XTS 256 > GEOM_ELI: Crypto: hardware > vboxdrv: fAsync=0 offMin=0x2e4 offMax=0x1090 -- End of security output --
