Cannot mount Samba share
mvalzelli
Hi everyone, I'm trying to mount a smb share on a macOS client. I have the following setup:
The storage is simple:
with Windows permission:
I have created a user with the relative groups:
I have configured the share as:
and the samba service as
Screen Shot 2017-06-20 at 21.35.14.png Screen Shot 2017-06-20 at 21.35.22.png
When trying to mount the share I get the following error:
Does anyone have any suggestion of why it doesn't work?
(I also trying using the Finder, but it doesn't work either).
Thanks everyone
anodos
Sambassador
Mac? Not too familiar with OSX CLI. Perhaps try it without 'sudo' and include the workgroup in your command. mount -t smbfs mattia@freenas/Media ~/Desktop/test Alternatively, you can use 'open' open 'smb://mattia:password@freenas/Media'
mvalzelli
Thanks for your help. Unfortunately I get the same error
server connection failed: Socket is not connected
mvalzelli
[root@freenas ~]# testparm
Load smb config files from /usr/local/etc/smb4.conf
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
Processing section "[Media]"
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
		dos charset = CP437
		lm announce = Yes
		logging = file
		max log size = 51200
		kernel change notify = No
		pid directory = /var/run/samba
		disable spoolss = Yes
		load printers = No
		printcap name = /dev/null
		time server = Yes
		map to guest = Bad User
		obey pam restrictions = Yes
		security = USER
		server role = standalone server
		deadtime = 15
		max open files = 233705
		dns proxy = No
		idmap config * : backend = tdb
		store dos attributes = Yes
		strict locking = No
		directory name cache size = 0
		dos filemode = Yes
		acl allow execute always = Yes
		ea support = Yes
		create mask = 0666
		directory mask = 0777
[Media]
		path = "/mnt/tank/Media"
		veto files = /.snapshot/.windows/.mac/.zfs/
		read only = No
		vfs objects = zfs_space zfsacl streams_xattr aio_pthread
		zfsacl:acesort = dontcare
		nfs4:chown = true
		nfs4:acedup = merge
		nfs4:mode = special
anodos
Sambassador
# Global parameters
[global]
		dos charset = CP437
		lm announce = Yes
		logging = file
		load printers = No
		time server = Yes
		security = USER
		deadtime = 15
		dns proxy = No
		strict locking = No
		dos filemode = Yes
		ea support = Yes
		create mask = 0666
[Media]
		read only = No
		nfs4:chown = true
		nfs4:acedup = merge
		nfs4:mode = special
Post output of getfacl /mnt/tank/Media. Also try increasing logging level under "services"->"SMB" to "Debug", try to connect, get the socket error, then post the contents of /var/log/samba4/log.smbd here. My hunch is that this is a client (OSX) problem. While you're at it, check for updates to your client OS.
mvalzelli
[root@freenas ~]# getfacl /mnt/tank/Media/
# file: /mnt/tank/Media/
# owner: mattia
# group: shared
			owner@:rwxpDdaARWcCos:fd-----:allow
			group@:rwxpDdaARWcCos:fd-----:allow
		 everyone@:r-x---a-R-c---:fd-----:allow
Attached the output of log.smbd. Also I can confirm that using an ubuntu VM on the same client mounts the share correctly. Any hints on how drill down the problem/workaround?
Thank you for your time and help!
  • log.txt
anodos
Sambassador
It looks like your OSX client is negotiating a supported protocol, then stopping and sitting there. No attempt to authenticate (i.e. no SMB2 SESSION_SETUP messages). After one minute of sitting there, samba decides that the connection is pining for the fjords and kills its process deader with a SIGTERM.
Now the question is, why is OSX doing that? Perhaps it needs you to supply a password in the mount -t smbfs command. The OSX manpage has this example: mount -t smbfs //username:userpass@myserver/PUBLIC /smb/public
You can add the "fruit" VFS object to all of your shares (yes, all of them). This generally improves OSX support by providing support for SMB2 AAPL extensions. I believe the presence of these are determined during SMB2 TREE_CONNECT, which occurs after NEGOTIATE and SESSION_SETUP, and so this won't help your particular problem (but it will help with later problems you discover once you get authentication working). ;)
mvalzelli
Added the "fruit" attribute to the share (I have only one for now), restarted smbd and used the mount command with the password. Still no change, the command still returns "mount_smbfs: server connection failed: Socket is not connected".
Attached the new log.
  • log.txt
anodos
Sambassador
What version of OSX is this?
SweetAndLow
Sweet'NASty
If you go to the networking section in the finder can you see the shares and connect? You can also try the connect to server option under the main menu bar.
mvalzelli
I can see the share from the Finder, but if I try to connect using the "Connect to server" option in Finder, I can insert the credentials but tells me a generic error. I used the command line because at least it gives me an actual error ("mount_smbfs: server connection failed: Socket is not connected").
SweetAndLow
Sweet'NASty
The error you are getting on the command line isn't a good message either. What happens when you connect in the finder? What error and what error when you use connect to server? Is there any AD(time sync issues?) or other things on your network that make this not a normal setup?
EDIT:
can you use the smbutil tool to debug stuff? Maybe try smbutil view //username@<server ip>
EDIT 2: You can also try making a guest access only share to see if that connects. This will rule out any auth problems.
mvalzelli
EDIT:
Even with guest enabled using "smbutil" gets the same error: "smbutil: server connection failed: Socket is not connected"
anodos
Sambassador
Give full details of your network topology. Turn off firewall. Perform a packet trace from the OSX client. You can probably restrict the pcap to only traffic to/from the FreeNAS server by adding "host <ip of freenas>" to the tcpdump command.
Warhammer
Hello all. I have the same problem. SMB share mounts from Win10 but doesn't want from MAC OS X Sierra 10.12.6. QQ to topic starter. Had you resolved your problem?
