SOLVED Cannot delete CloudShare folder from volume on Freenas 9.3
Estropelic
I was working on installing CloudShare and moved onto another project. Now, the folder for cloudshare is locked under root user and I cannot delete the folder. Whats the best way for me to delete this folder. I would appreciate any help on this issue.
D
dlavigne
Guest
It is most likely a dataset. If so, remove the dataset from Storage -> Volumes.
D
dlavigne
Guest
No, you'll lose everything within that dataset. If you used plugins or jails to install Cloudshare, it should have made a dataset for you.
Estropelic
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/daily/405.status-ata-raid: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/daily/409.status-gconcat: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/daily: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/security/520.pfdenied: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/security/400.passwdless: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/security/800.loginfail: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/security: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/weekly/400.status-pkg: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/weekly/999.local: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/weekly/330.catman: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/weekly/310.locate: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/weekly/320.whatis: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/weekly/340.noid: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/weekly: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/monthly/200.accounting: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/monthly/999.local: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic/monthly: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/periodic: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/pkg/FreeBSD.conf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/pkg: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/csh.login: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/rc.bsdextended: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/network.subr: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/devd.conf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/rc: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/dhclient.conf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mtree/BSD.sendmail.dist: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mtree/BSD.usr.dist: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mtree/BIND.chroot.dist: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mtree/BSD.var.dist: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mtree/BSD.include.dist: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mtree/BSD.root.dist: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/freebsd.mc: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/submit.cf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/helpfile: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/aliases: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/access.sample: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/README: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/freebsd.submit.cf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/freebsd.cf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/virtusertable.sample: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail/mailertable.sample: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/mail: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/nsswitch.conf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/ttys: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/inetd.conf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/ntp.conf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/libmap32.conf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/security/audit_event: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/security/audit_class: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/security: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/termcap.small: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/rc.subr: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/gss/qop: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/gss/mech: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc/gss: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/etc: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/.cshrc: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/.profile: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/boot/device.hints: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/boot: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/COPYRIGHT: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/crash: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named/etc/namedb/named.root: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named/etc/namedb/named.conf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named/etc/namedb/master/localhost-reverse.db: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named/etc/namedb/master/localhost-forward.db: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named/etc/namedb/master/empty.db: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named/etc/namedb/master: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named/etc/namedb: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named/etc: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var/named: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/var: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/root/.login: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/root/.k5login: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/root/.cshrc: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/root/.profile: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current/root: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate/current: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/etcupdate: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/ports: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/freebsd-update: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/portsnap: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/pkg/local.sqlite: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/pkg/FreeBSD.meta: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/pkg/repo-FreeBSD.sqlite: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/pkg: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db/entropy: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/db: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/backups: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/spool/mqueue: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/spool/lock: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/spool/lpd: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/spool/opielocks: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/spool/output/lpd: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/spool/output: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/spool/clientmqueue: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/spool: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/cache/pkg/subversion-1.8.11-5343038fd7.txz: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/var/cache/pkg/ca_root_nss-3.18-70a39f0c6f.txz: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/dev: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/mount_mfs: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/resolvconf: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/graid: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/kldconfig: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/zpool: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/growfs: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/routed: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/clri: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/conscontrol: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/mdmfs: Operation not permitted
Apr 6 09:28:18 freenas notifier: chmod: /mnt/FREENASPOOL/CloudShare/jails/.warden-template-pluginjail/sbin/ipfs: Operation not permitted
Apr 6 09:28:24 freenas notifier: chmod: /mnt/FREENASPOOL: Operation not permitted
D
dlavigne
Guest
What command gave that output?
Did you try to delete the CloudShare dataset from Volume Manager?
Estropelic
The dataset that Cloudshare resides in is my primary share dataset. If I remove the dataset, I'll lose all my data.
D
dlavigne
Guest
I'm confused. Why are you trying to remove it then? Is jails a dataset underneath it? Again, a screenshot of Volume Manager or a zfs list would be useful...
Estropelic
Here you go
D
dlavigne
Guest
Nope, that's neither Volume Manager or zfs list. Those will indicate whether or not there are sub-datasets below CloudShare or if you're stuck with what you have...
SweetAndLow
Sweet'NASty
Why can't you delete the jails dataset?
Also you shouldn't share the root of the pool like you are. Create a dataset specific for your smb share. When accessing your files from Windows I suggest never touching the jail files.
Estropelic
Can you refer me to a how-to for creating data-sets. The reason why I left all the volume space for data was because you cannot expand volumes once created.
SweetAndLow
Sweet'NASty
This question makes me think you should do way more reading. To start there are excellent freenas docs that describe everything in the gui. Here is how to create datasets
http://doc.freenas.org/9.3/freenas_storage.html#create-dataset
At the same time I'll point out that datasets have nothing to do with expanding your volume. Have you read the noob guide? If not it's required reading and linked all over the forum and in the beginner section.
