Cannot create volumes 9.2.0-x64
toretti
I'm new of FreeNas and I have an issue on FreeNAS-9.2.0-RELEASE-x64.
if I try to auto import volumes , no volume are detected.
If I try to create zfs volume manually I can see drives but, it request me to set a value in empty field , as in attached image.
even if i skip that and try to create volume, then no volumes will be displayed in volume manager
Already tried to wipe all disks, but even this didn't help.
Probably I'm doing something wrong so please support me, thanks in advance
toretti
I've noticed it gives me the error:
Error: Unable to GPT format the disk "ada0"
HoneyBadger
actually does care
Administrator
It sounds like it's not able to recognize your disk for some reason. What's your motherboard/SATA controller information?
If you don't have anything of value on those disks, maybe boot into an alternate liveCD and try re-initializing/partitioning them from there.
