I am running FreeNAS-8.0.2-RELEASE-amd64 (8288) on Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz. Memory 8086MB.
The motherboard is P8H67-M EVO with 4 SATA disks in RAIDZ.
Everything is fine until I tried connecting external storage through USB. I tried a USB stick and an external HD ("500 GB Essential") and have the same problem with both.
Going into Storage/Volumes/CreateVolume the USB memory shows up (e.g. as da0). I tried both ZFS and UFS and it works.
But, going into Storage/Volumes/ShowAllVolumes does not display the new volume. However, it is shown under Storage/Volumes and I can click on ChangePermissions but then a warning window shows saying that an error occured (actually in Swedish, a bit strange since nothing else in FreeNAS is in Swedish. I am Swedish though). If I remove the USB memory and reboot then it is gone from Storage/Volumes/ShowAllVolumes.
I have tried several USB ports. Anyone who can help?
