Cannot connect to my FreeNAS
falukky
So i have FreeNAS version 9.x and last days I cannot connect the NAS via windows, so I connect screen and this is what I have seen:
This morning after several reboots I successfully succeed to connected the NAS folder but I cannot doing anything, it looks like it is all stuck.
I also connect to the web GUI and saw red alert.
EDIT:
i have 6 hard drive X 2TB and the FreeNAS define with 2 hard drive as backup.
...and it says...?
You're getting disk errors on ada2. Either the disk is toast, or the cable or SATA port is defective.
falukky
But I remember that i have 2 disks define as backup (Raid-Z2 maybe ?)
So if only one driver is failed why the system cannot run?
Chris Moore
But i remember that i have 2 disks define as backup (Raid-Z2 maybe ?)
So if only one driver is failed why the system cannot run ?
We need more info to answer.
You need to click on the alert and give us a screen shot of what it says.
Chris Moore
You can also tell us what hardware you are using. The more you can tell us, the better we can help.
falukky
Ok this is my Screenshot:
I removed one hard disk that i though is the one who cause the problem and the NAS now working but i still have this error in my screenshot.
BTW can i update to version 11 without reinstall all ?
gpsguy
Active Member
Please slow down and don't remove stuff randomly. It looks like you have problems with your boot volume and your data volume.
Please post the results of zpool status using code tags.
You need to fix these issues, before you consider an upgrade.
Chris Moore
Please follow the advice @gpsguy gave so we can help you fix one thing at a time.
I can see that there are several problems.
First, one of the boot disks (you must have had a mirror) has failed and we need to get that replaced.
Then, it appears that your storage pool may have a faulty drive also, but we need to see that zpool status to know for sure.
After that, your pool is over 80% filled, so we should look at adding some storage or removing some data.
Last, unless something else comes up, then we look at the update. Best to have it all working first.
falukky
What exactly i need to do ? (i am totally new with FreeNAS )
falukky
Currently i removed 1 hard drive so now i have only 5.
What i need to do now ?
falukky
And why you told me to remove some data if only 80% filled ?
gpsguy
Active Member
Your volume is 85% full. The warning shows up at 80%. At 90% full, performance will start to tank and if you let it go to 100% you'll end up in a world of hurt where you can't delete files easily.
gpsguy
Active Member
I won't be able to resume help for a few hours. Wait for others to chime in.
In the meantime you might want to download a copy of the documentation. For version 9.3 and later, you can get it via a link in my signature. Get the version that matches your FreeNAS version.
Read up on "save configuration". Download the configuration before your boot drive completely dies.
Sorry I can't write more. I am doing this on my cell phone.
Chris Moore
How did you get the system set up to begin with?
Chris Moore
Can you put the hard disk drive back in the system?
falukky
Do you think its better to reinstall my FreeNAS and install version 11 ?
I have backup all my data so it wont be problem to do that.
@Chris Moore now i am copy all my data so after that i will try to connect the hard drive back to the system (its going to take several hours)
