SOLVED Can I use serial interface (RS-232) into a Jail
thibodude
Hi, I'm using TrueNAS-12.0-U6.1
I'm trying to use the COM1 serial RS-232 (0x3f8) @ 19200 from a Node-Red plugin (Jail).
From Truenas Core >_ Shell (GUI)
ls -ls /dev/cuau* shows /dev/cuau0 and /dev/cuau2 available
BUT from jail's >Shell I see a short list without /dev/cuau...
My question is:
Is it possible that a jail like Node-Red plugin cannot use a serial interface ?
Is there a workaround, like esxi hardware passthrough ?
Any help is appreciated !
Thanks in advance
Samuel Tai
Yes, but you need to set mount properties in the jail and security tunables outside the jail. Basically, you need to have the host export the device special files in /dev to the jail, so the jail sees them in the jail's /dev directory.
First, on the host, go to System->Tunables, and set the following sysctl tunables:
VariableValue
security.jail.enforce_statfs0
security.jail.mount_allowed1
security.jail.mount_devfs_allowed1
security.jail.mount_procfs_allowed1
Next, in the jail settings, set the following
PropertyValue
devfs_ruleset0
securelevel0
allow_mountchecked
allow_mount_*allow_mount_devfs, allow_mount_procfs
thibodude
Thanks for the quick response !
Question: Type: Loader, rc.conf or sysctl ?
Samuel Tai
sysctl
thibodude
Sorry I should have seen before, you wrote it down the first time !
I did that and rebooted TrueNAS... I can now see /dev/cuau0 and /dev/cuau2 under Node-Red Jail >_ ls -la /dev/cua*
But it doesn't seem to work... My serial Insteon PLM is not responding under Node-Red, neither under /dev/cuau0 noe /dev/cuau2... Always shows disconnected. Any clue ?
Samuel Tai
Are you running as root? Typically, devices in /dev are only accessible to processes running as root.
Samuel Tai
No, I mean the Node-RED software. What account is it running as? Looking at the permissions for the /dev/cuau* devices on my system, they're readable and writeable for the uucp account and the dialer group. If Node-RED uses its own account other than group, you may need to add that account as a member of the dialer group in /etc/group by adding that account to the line for the dialer group:
dialer:*:68:<add Node-RED account here>
thibodude
I see... Node-Red uses it's own user ie. nodered I guess but not sure...
Here:
root@truenas[/mnt/TNPool/iocage/jails/NodeRed]# ls -al
total 52
drwxr-xr-x   4 root  wheel     7 Nov 23 16:05 .
drwxr-xr-x   5 root  wheel     5 Nov 23 16:22 ..
-rw-r--r--   1 root  wheel   629 Nov 23 16:05 config.json
-rw-r--r--   1 root  wheel  1641 Nov 19 09:12 fstab
-rw-r--r--   1 root  wheel   667 Nov 19 09:12 node-red.json
drwxr-xr-x   5 root  wheel     8 Nov 19 10:00 plugin
drwxr-xr-x  18 root  wheel    22 Nov 19 09:12 root
Question: How do I add it to the dialer group ?
root@truenas[~]# cat /etc/group
wheel:*:0:
daemon:*:1:
kmem:*:2:
sys:*:3:
tty:*:4:
operator:*:5:uucp
mail:*:6:
bin:*:7:
news:*:8:
man:*:9:
games:*:13:
ftp:*:14:
staff:*:20:
sshd:*:22:
smmsp:*:25:
mailnull:*:26:
guest:*:31:
bind:*:53:
proxy:*:62:
authpf:*:63:
_pflogd:*:64:
_dhcp:*:65:
uucp:*:66:
dialer:*:68:
network:*:69:
audit:*:77:
ladvd:*:78:
www:*:80:
ntpd:*:123:
avahi:*:200:
messagebus:*:201:
nslcd:*:389:
consul:*:469:
nomad:*:472:
minio:*:473:
builtin_administrators:*:544:
builtin_users:*:545:admin,rsync
builtin_guests:*:546:
webdav:*:666:
hast:*:845:
michel:*:1000:
mthibode:*:1001:
rsync:*:1002:
nogroup:*:65533:
nobody:*:65534:
media:*:8675309:
root@truenas[~]#
Samuel Tai
Inside the jail, what's the contents of /etc/passwd and /etc/group? You provided the host's /etc/group.
thibodude
Sorry !
root@truenas[.../TNPool/iocage/jails/NodeRed/root/etc]# cat group
# $FreeBSD: releng/12.2/etc/group 359447 2020-03-30 17:07:05Z brooks $
wheel:*:0:root
daemon:*:1:
kmem:*:2:
sys:*:3:
tty:*:4:
operator:*:5:root
mail:*:6:
bin:*:7:
news:*:8:
man:*:9:
games:*:13:
ftp:*:14:
staff:*:20:
sshd:*:22:
smmsp:*:25:
mailnull:*:26:
guest:*:31:
video:*:44:
bind:*:53:
unbound:*:59:
proxy:*:62:
authpf:*:63:
_pflogd:*:64:
_dhcp:*:65:
uucp:*:66:
dialer:*:68:
network:*:69:
audit:*:77:
www:*:80:
ntpd:*:123:
_ypldap:*:160:
hast:*:845:
tests:*:977:
nogroup:*:65533:
nobody:*:65534:
nodered:*:1880:
root@truenas[.../TNPool/iocage/jails/NodeRed/root/etc]# cat passwd
# $FreeBSD: releng/12.2/etc/master.passwd 359447 2020-03-30 17:07:05Z brooks $
root:*:0:0:Charlie &:/root:/bin/csh
toor:*:0:0:Bourne-again Superuser:/root:
daemon:*:1:1:Owner of many system processes:/root:/usr/sbin/nologin
operator:*:2:5:System &:/:/usr/sbin/nologin
bin:*:3:7:Binaries Commands and Source:/:/usr/sbin/nologin
tty:*:4:65533:Tty Sandbox:/:/usr/sbin/nologin
kmem:*:5:65533:KMem Sandbox:/:/usr/sbin/nologin
games:*:7:13:Games pseudo-user:/:/usr/sbin/nologin
news:*:8:8:News Subsystem:/:/usr/sbin/nologin
man:*:9:9:Mister Man Pages:/usr/share/man:/usr/sbin/nologin
sshd:*:22:22:Secure Shell Daemon:/var/empty:/usr/sbin/nologin
smmsp:*:25:25:Sendmail Submission User:/var/spool/clientmqueue:/usr/sbin/nologin
mailnull:*:26:26:Sendmail Default User:/var/spool/mqueue:/usr/sbin/nologin
bind:*:53:53:Bind Sandbox:/:/usr/sbin/nologin
unbound:*:59:59:Unbound DNS Resolver:/var/unbound:/usr/sbin/nologin
proxy:*:62:62:Packet Filter pseudo-user:/nonexistent:/usr/sbin/nologin
_pflogd:*:64:64:pflogd privsep user:/var/empty:/usr/sbin/nologin
_dhcp:*:65:65:dhcp programs:/var/empty:/usr/sbin/nologin
uucp:*:66:66:UUCP pseudo-user:/var/spool/uucppublic:/usr/local/libexec/uucp/uucico
pop:*:68:6:Post Office Owner:/nonexistent:/usr/sbin/nologin
auditdistd:*:78:77:Auditdistd unprivileged user:/var/empty:/usr/sbin/nologin
www:*:80:80:World Wide Web Owner:/nonexistent:/usr/sbin/nologin
ntpd:*:123:123:NTP Daemon:/var/db/ntp:/usr/sbin/nologin
_ypldap:*:160:160:YP LDAP unprivileged user:/var/empty:/usr/sbin/nologin
hast:*:845:845:HAST unprivileged user:/var/empty:/usr/sbin/nologin
tests:*:977:977:Unprivileged user for tests:/nonexistent:/usr/sbin/nologin
nobody:*:65534:65534:Unprivileged user:/nonexistent:/usr/sbin/nologin
nodered:*:1880:1880:User &:/var/db/nodered:/usr/local/bin/bash
Samuel Tai
OK, as I thought, there's a nodered user that needs to be added to the dialer group. Within the jail, try pw usermod nodered -G dialer. Afterwards, check the /etc/group via grep dialer /etc/group, and you should see nodered appended as a member after the last colon.
Note, you'll need to run this inside the jail shell.
thibodude
Yeah I did restarted nodered after and now it works !
Thank you very much for your help Samuel I appreciated your easy to follow directives !
Michel
