I have older FreeNAS 9.3 at home with 2 data disks in ZFS pool.
One disk failed and I remove it from pc.
Unfortunately then I made offline and detach failed disk with zpool and now I have this situation.
Am I right?
Question is if I`m able to rebuild mirror array without data lost.,,,maybe via zpool?
I know, I can backup data, destroy pool and make another one with Volume manager via web....this is my last possible way, but I`d like to try rebuild array with more sophisticated.....is it possible?
It`s ZFS.zpool status
pool: Backup
state: ONLINE
scan: scrub repaired 0 in 1h1m with 0 errors on Sun Feb 6 01:01:09 2022
NAME STATE READ WRITE CKSUM
Backup ONLINE 0 0 0
gptid/75d491d5-8ce5-11eb-800c-009c02abdcba ONLINE 0 0 0
errors: No known data errors
I think I made mistake because now pool working with only 1 disk and I try to add another disk it will be stripe array not mirror.mount
freenas-boot/ROOT/default on / (zfs, local, noatime, nfsv4acls)
devfs on /dev (devfs, local, multilabel)
tmpfs on /etc (tmpfs, local)
tmpfs on /mnt (tmpfs, local)
tmpfs on /var (tmpfs, local)
freenas-boot/grub on /boot/grub (zfs, local, noatime, nfsv4acls)
Backup on /mnt/Backup (zfs, local, nfsv4acls)
Backup/Public on /mnt/Backup/Public (zfs, local, nfsv4acls)
Backup/Test on /mnt/Backup/Test (zfs, local, nfsv4acls)
Backup/.system on /var/db/system (zfs, local, nfsv4acls)
Backup/.system/cores on /var/db/system/cores (zfs, local, nfsv4acls)
Backup/.system/samba4 on /var/db/system/samba4 (zfs, local, nfsv4acls)
Backup/.system/syslog-5ece5c906a8f4df886779fae5cade8a5 on /var/db/system/syslog-5ece5c906a8f4df886779fae5cade8a5 (zfs, local, nfsv4acls)
Backup/.system/rrd-5ece5c906a8f4df886779fae5cade8a5 on /var/db/system/rrd-5ece5c906a8f4df886779fae5cade8a5 (zfs, local, nfsv4acls)
Backup/.system/configs-5ece5c906a8f4df886779fae5cade8a5 on /var/db/system/configs-5ece5c906a8f4df886779fae5cade8a5 (zfs, local, nfsv4acls)
Am I right?
