This is related to the problem I posted here.. https://forums.freenas.org/index.php?posts/443033
I currently have some scripts running rsync to sync files in FreeNAS to another Windows machine. There are some problems and I need to upgrade rsync to fix it.
My question is if I install latest rsync in a jail, i must also run the script in the jail in order to use the latest rsync in that jail?
Currently the rsync script is outside jail and I need to run it using root (through the rsync function via GUI). If I install rsync in jail, how can I run it as a root to sync files in the host (outside the jail).
