SmilingInSeattle
- Apr 21, 2012
I would like to create a new boot USB for an existing Freenas server, but I don't want to pull down the server and move it to monitors and a keyboard to do so.
While the server is running the latest version of Freenas 9.3, with the current update patches, the existing USB stick is getting old. I recently bought two quality USB 3.0 sticks with the intent of mirroring the existing drive, but found they to be too small by about 200MB to do so.
Therefore, I'd like to use another computer to run the latest Freenas 9.3 iso on and create a new Freenas flash drive on it, using the curses menu to force as much of the networking information that I have, save the latest configuration on another machine on the network, detach my zpool, shut down my Freenas server, pull the old OS stick out, put the new one in, reboot the server, and reattach the existing zpool . Once I reboot the server, my plan would be to upload the saved configuration db, put the 'sister' USB stick I just bought in another USB port and then create a mirror for the sake of having a current "failsafe" backup USB OS disk. And now I see one more thing, if that works: buy a couple more of the same brand/model USB sticks as I just bought so I create future failsafe backups!
