CAM errors with SSD - Delays during start up.
Delmir
I see the following errors during system start up o a brand new install:
ahcich0: is 00000000 cs 00000000 ss 00000400 rs 00000400 tfd 40 serr 00000000 cmd 0000ca17
(ada0:ahcich0:0:0:0): SEND_FPDMA_QUEUED DATA SET MANAGEMENT. ACB: 64 01 00 00 00 40 00 00 00 00 00 00
(ada0:ahcich0:0:0:0): CAM status: Command timeout
(ada0:ahcich0:0:0:0): Error 5, Retries exhausted
ada0 is an SSD (cheap: Silicon Power) and it's the boot device which is connected straight on the motherboard's SATA port (Dell T20). The other drives are connected via an HBA (LSI 9211-8i).
While the system waits for those CAM commands to timeout, the NAS becomes non-responsive. Everything goes back to normal after 2 or 3 minutes and remains good until next reboot.
smartctl shows "Log not supported" for this SSD. Is this common? Please see dmesg and smartctl outpus attached.
Is this a sign of a bad/unsupported device? Should it be reported as a bug to FreeNAS or FreeBSD? Any clues would be greatly appreciated.
  • dmesg.txt
  • ada0-smartctl.txt
HoneyBadger
actually does care
Administrator
My hunch based on the reference to DATA_SET_MANAGEMENT is that either the device or FreeBSD don't properly support TRIM (maybe queued TRIM?)
If you have no other SSDs (and don't plan to add any more) I'd suggest disabling TRIM and see if that resolves the errors.
Delmir
Okay. Would anyone please advise if this is the correct way to turn off TRIM?
"vfs.zfs.trim.enabled=0" was added to /boot/loader.conf and after rebooting I no longer get those CAM errors!!!
root@freenas[~]# sysctl vfs.zfs.trim
vfs.zfs.trim.enabled: 0
vfs.zfs.trim.max_interval: 1
vfs.zfs.trim.timeout: 30
vfs.zfs.trim.txg_delay: 32
root@freenas[~]#
More questions:
What would be the implications of not using TRIM? Is there a way to trim manually once a while? If so, how?
Why doesn't TUNEFS work? Is it because the filesystems is ZFS instead of UFS?
root@freenas[~]# tunefs -t disable /dev/ada0p2
tunefs: /dev/ada0p2: could not read superblock to fill out disk
root@freenas[~]# tunefs -p /dev/ada0
tunefs: /dev/ada0: could not read superblock to fill out disk
root@freenas[~]# tunefs -p /dev/ada0p2
root@freenas[~]#
root@freenas[~]# gpart show
=> 40 500118112 ada0 GPT (238G)
40 1024 1 freebsd-boot (512K)
1064 33554432 3 freebsd-swap (16G)
33555496 466550784 2 freebsd-zfs (222G)
500106280 11872 - free - (5.8M)
HoneyBadger
actually does care
Administrator
That is the right way to disable TRIM; glad to hear that's mitigated the issue.
SSDs without TRIM will basically reduce performance over time due to having to erase dirty cells at write time, rather than being able to do that during their idle cycles. Internal garbage collection on the drive itself can help with this though.
As far as running TRIM manually, I wouldn't. Given the reaction of the drive/controller to TRIM requests (throwing errors) I'd be worried about data safety if it decides to barf and zero out the wrong cells.
Samuel Tai
Note, you should set "vfs.zfs.trim.enabled=0" as a loader tunable, and not edit the file directly.
Patrick M. Hausen
@Delmir
TUNEFS(8)               FreeBSD System Manager's Manual              TUNEFS(8)
NAME
     tunefs - tune up an existing UFS file system
frozenduck
Sorry for the very Newbie question. I have a similar problem in that TRIM is causing my new SSD (boot pool) to be flagged as degraded. I think that I need to add vfs.zfs.trim.enabled=0 to the sysctl.conf but it doesn't write out in the Shell. How do I actually change tunables?
Patrick M. Hausen
System -> Tunables in the UI. Probably type "loader" for this one.
Patrick M. Hausen
Patrick M. Hausen
No luck with either "loader" or "sysctl" types ... Thanks anyway. Will keep tinkering.
What precisely did you enter? Care to share a screenshot? BTW loader is correct, see @Samuel Tai's post above.
Samuel Tai
Note loader tunables only take effect on the next reboot. Under System->Tunables, click the Add button, and fill out the ensuing dialog like this:
Click Save, and reboot.
frozenduck
Thanks. The example helped and it worked after the 3rd save and reboot. Now "sysctl vfs.zfs.trim" returns as enabled=0, but the disk is still flagged as degraded. Scrubbed a couple of times and it doesn't seem to have changed status, so I guess that maybe the disk is actually degraded, or just incompatible with FreeNAS. Although at less than a month in the machine from new, I am a little surprised. It still seems to boot fine, so I am not sure what the problem is. Thanks again for the help.
