Disks go offline, reboot fixes it...
stallione
I am trying to figure out what is causing this behavior, two of my disks go offline (either one at a time) and a reboot fixes it. I reconnected the SATA cables, reseated them and the power supply cables etc. Looking for ideas to figure out if this is an issue with my hardware or a software glitch because a reboot fixes it every time.
kernel log messages:
> ahcich10: Timeout on slot 17 port 0
> ahcich10: is 00000002 cs 00000000 ss 00000000 rs 00020000 tfd 50 serr 00000000 cmd 00047117
> (aprobe0:ahcich10:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
> (aprobe0:ahcich10:0:0:0): CAM status: Command timeout
> (aprobe0:ahcich10:0:0:0): Error 5, Retry was blocked
> ahcich10: Timeout on slot 24 port 0
> ahcich10: is 00000002 cs 00000000 ss 00000000 rs 01000000 tfd 50 serr 00000000 cmd 00047817
-- End of security output --
Similarly,
> ahcich11: Timeout on slot 22 port 0
> ahcich11: is 00000002 cs 00000000 ss 00000000 rs 00400000 tfd 50 serr 00000000 cmd 00047617
> (aprobe0:ahcich11:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
> (aprobe0:ahcich11:0:0:0): CAM status: Command timeout
> (aprobe0:ahcich11:0:0:0): Error 5, Retry was blocked
> (ada7:ahcich11:0:0:0): lost device
and the result is this
pool: Vol1_Z2
state: DEGRADED
status: One or more devices has been removed by the administrator.
    Sufficient replicas exist for the pool to continue functioning in a
    degraded state.
action: Online the device using 'zpool online' or replace the device with
    'zpool replace'.
  scan: resilvered 52.4M in 0h0m with 0 errors on Wed Feb  5 08:28:36 2014
    NAME                                            STATE    READ WRITE CKSUM
    Vol1_Z2                                        DEGRADED    0    0    0
      raidz2-0                                      DEGRADED    0    0    0
        gptid/1726809e-6fd3-11e3-82e4-6805ca036bbd  ONLINE      0    0    0
        6019324666217575707                        REMOVED      0    0    0  was /dev/gptid/1791a0bf-6fd3-11e3-82e4-6805ca036bbd
        gptid/17fb544b-6fd3-11e3-82e4-6805ca036bbd  ONLINE      0    0    0
        gptid/186595a7-6fd3-11e3-82e4-6805ca036bbd  ONLINE      0    0    0
        gptid/18d4b6c5-6fd3-11e3-82e4-6805ca036bbd  ONLINE      0    0    0
        gptid/1940235e-6fd3-11e3-82e4-6805ca036bbd  ONLINE      0    0    0
errors: No known data errors
Any help or guidance would be much appreciated!
joeschmuck
Old Man
If you have any data you want to keep, back it up now! If you end up dropping three drives at the same time you data may all be lost. Once you have done that I'd run a short smart test first to see if there is something you find right away, then a long test. Also could you post the results of 'smartctl -a' results for the drives? Is it always the same two drives?
Good luck.
stallione
Thanks for the quick reply. Do you think that this could be a disk issue rather than a controller/software problem?
Here are the smartctl -a for the two drives in question.
 smartctl -a /dev/ada6
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:    Hitachi Deskstar 7K1000.C
Device Model:    Hitachi HDS721010CLA332
Serial Number:    JP9960HZ20DJJU
LU WWN Device Id: 5 000cca 375dc5e0e
Firmware Version: JP4OA3MA
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
ATA Version is:  ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Sat Feb  8 09:53:09 2014 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
Self-test execution status:      (  0) The previous self-test routine completed
                                        been run.
data collection:                (10047) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (  1) minutes.
Extended self-test routine
recommended polling time:        ( 167) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate    0x000b  100  100  016    Pre-fail  Always      -      1
  2 Throughput_Performance  0x0005  135  135  054    Pre-fail  Offline      -      96
  3 Spin_Up_Time            0x0007  119  119  024    Pre-fail  Always      -      320 (Average 315)
  4 Start_Stop_Count        0x0012  100  100  000    Old_age  Always      -      62
  5 Reallocated_Sector_Ct  0x0033  100  100  005    Pre-fail  Always      -      0
  7 Seek_Error_Rate        0x000b  100  100  067    Pre-fail  Always      -      0
  8 Seek_Time_Performance  0x0005  138  138  020    Pre-fail  Offline      -      31
  9 Power_On_Hours          0x0012  097  097  000    Old_age  Always      -      23858
10 Spin_Retry_Count        0x0013  100  100  060    Pre-fail  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      61
192 Power-Off_Retract_Count 0x0032  100  100  000    Old_age  Always      -      90
193 Load_Cycle_Count        0x0012  100  100  000    Old_age  Always      -      90
194 Temperature_Celsius    0x0002  193  193  000    Old_age  Always      -      31 (Min/Max 18/37)
196 Reallocated_Event_Count 0x0032  100  100  000    Old_age  Always      -      0
197 Current_Pending_Sector  0x0022  100  100  000    Old_age  Always      -      0
198 Offline_Uncorrectable  0x0008  100  100  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x000a  200  200  000    Old_age  Always      -      1
SMART Error Log Version: 1
ATA Error Count: 1
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 22879 hours (953 days + 7 hours)
  ER ST SC SN CL CH DH
  84 51 b0 60 be aa 00  Error: ICRC, ABRT at LBA = 0x00aabe60 = 11189856
  CR FR SC SN CL CH DH DC  Powered_Up_Time  Command/Feature_Name
  61 d0 b0 40 be aa 40 00  2d+09:14:18.207  WRITE FPDMA QUEUED
  61 00 b0 40 bd aa 40 00  2d+09:14:18.201  WRITE FPDMA QUEUED
  61 00 b0 40 bc aa 40 00  2d+09:14:18.194  WRITE FPDMA QUEUED
  61 00 b0 40 bb aa 40 00  2d+09:14:18.185  WRITE FPDMA QUEUED
  61 00 b0 40 ba aa 40 00  2d+09:14:18.177  WRITE FPDMA QUEUED
# 1  Short offline      Completed without error      00%    23692        -
# 2  Short offline      Completed without error      00%    23680        -
# 3  Extended offline    Completed without error      00%    23661        -
# 4  Short offline      Completed without error      00%    23524        -
# 5  Short offline      Completed without error      00%    23359        -
# 6  Short offline      Completed without error      00%    23347        -
# 7  Extended offline    Completed without error      00%    23304        -
# 8  Extended offline    Completed without error      00%    23194        -
# 9  Short offline      Completed without error      00%    23167        -
#10  Short offline      Completed without error      00%    23155        -
#11  Short offline      Completed without error      00%    23060        -
#12  Short offline      Completed without error      00%    22965        -
#13  Extended offline    Completed without error      00%    22944        -
and
smartctl -a /dev/ada7
Serial Number:    JP2940HZ22P3BL
LU WWN Device Id: 5 000cca 375dd66fd
Local Time is:    Sat Feb  8 09:54:54 2014 CST
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                ( 9278) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 155) minutes.
  1 Raw_Read_Error_Rate    0x000b  100  100  016    Pre-fail  Always      -      0
  2 Throughput_Performance  0x0005  136  136  054    Pre-fail  Offline      -      92
  3 Spin_Up_Time            0x0007  119  119  024    Pre-fail  Always      -      321 (Average 315)
  8 Seek_Time_Performance  0x0005  140  140  020    Pre-fail  Offline      -      30
  9 Power_On_Hours          0x0012  097  097  000    Old_age  Always      -      23857
192 Power-Off_Retract_Count 0x0032  100  100  000    Old_age  Always      -      88
193 Load_Cycle_Count        0x0012  100  100  000    Old_age  Always      -      88
194 Temperature_Celsius    0x0002  181  181  000    Old_age  Always      -      33 (Min/Max 18/40)
199 UDMA_CRC_Error_Count    0x000a  200  200  000    Old_age  Always      -      0
SMART Error Log Version: 0
No Errors Logged
# 1  Short offline      Completed without error      00%    23691        -
# 2  Short offline      Completed without error      00%    23679        -
# 3  Extended offline    Completed without error      00%    23660        -
# 4  Short offline      Completed without error      00%    23523        -
# 5  Short offline      Completed without error      00%    23358        -
# 6  Short offline      Completed without error      00%    23346        -
# 7  Extended offline    Completed without error      00%    23302        -
# 8  Short offline      Completed without error      00%    23166        -
# 9  Short offline      Completed without error      00%    23154        -
#10  Short offline      Completed without error      00%    23059        -
#11  Short offline      Completed without error      00%    22963        -
#12  Extended offline    Completed without error      00%    22943        -
joeschmuck
Old Man
The drives appear to be fine to me. Did this problem just start and can you correlate it to ether a software change or hardware change, moving the case, something? What FreeNAS version are you running?
joeschmuck
Old Man
I'd start looking at hardware then. I'm not going to give you the ECC RAM speech, hopefully you have heard it before. First I'd replace the SATA cables for those 2 drives. If that doesn't fix it you can try to isolate it to the drives or the MB, shut down the system and take the two drives in question and swap the SATA connections on the MB to two other locations. Power up the system and see how it looks. If the fault follows the drives then I'd suspect the SATA cable or hard drives. If the failure moves to two different drives than it's the MB or software. You will have to take it slow and pay attention to what does or doesn't make a difference.
Yatti420
Sata cables.. Capacitors/Power supply?
