pro lamer
- Feb 16, 2018
I think it may be treated as a sanity check thread...
Should anyone use a 2TB or 3TB 2.5" HDD with the X9DRL-3F SAS/SATA2 ports - please post :)
Long story short: can one safely use X9DRL-3F's SCU's SAS/SATA2 ports for 2-3TB 2.5" SATA drives?
I've seen posts in our forums giving warnings about some SAS1 backplanes and some SAS1 hardware in general (including the hardware recommendation guide).
I hope it may not refer to the Intel C606 PCH though...
More details:
I guess I am right that C606 is SAS1 since I've seen somewhere it's 3Gbps.
I'm choosing between an X9DRL-3F or X9DRL-iF. The latter is available $15-$30 cheaper to me but has less SATA compatible connectors (10 vs.14). I'm tempted by more connectors onboard since initially I'm starting with a DIY open-case testbench and don't want any expansion cards (at least for now) but I'd like to be able to try more than one pool (possibly 3 pools) one of them a 6x2TB raidz2 2.5" pool... (or 7x2TB) with possible upgrade to 6/7x3TB in future. This is why I consider 10 SATA ports not necessarilly enough :p
Planned connection method: no expanders but mixture of plain cables and some SATA backplanes (not any unfamous SAS1 found in our forums).
The warning here
And is the C606 an old one?
And from the Hardware recommendation guide:
Still the Hardware recommendation guide:
More details:
The warning here
may refer to me or not - I've checked the supermicro's HDD compatiblity list for the motherboard's c600 SAS controller and there are many 6Gbps disks there so this stuff supports 6Gbps drives but again I don't know if it supports 6Gbps transfer rate...You probably want to avoid older controllers, cabling, expanders, etc. that doesn't support 6Gbps because some of it has "gotchas" in it.
It's Intel but on the other hand the supermicro compatibility list I mentioned above has even 4TB HDDs there (but not 2.5") while the list for SATA 3.5" (not 2.5) has 12TB disks.SAS1 (and why it should be avoided)
LSI SAS1 devices are well-supported in FreeNAS. However, due to hardware limitations, these HBAs are limited to drive sizes of 2.2TB or below. (...)
I guess if one encounters the quirks he/she has to be ready to change their drives to some other brand or buy an expansion card anyway...Finally, due to their age, SAS1 devices may have weird quirks when used with modern hardware.
