csmall
- Nov 22, 2015
What would be the best Supermicro micro ATX motherbaord to use with FreeNAS at this time? Would it be the X10SL7-F? Cost aside. Which micro ATX board gives you the most.
What specific CPU model would be recommended for use with the answer to the above?
I think I'm good on all other components.
Thanks!
Thanks!
Sent from my LG-H810 using Tapatalk
Thanks!
Thanks!
