build combined freenas/mediaplayer/accesspoint
afmobiwx
Hi forum,
i am using strictly linux in prod environment, but i switched to freenas on my file servers and xen storage. i tend to neglect my home stuff. now at home i have a cable router without wifi from my cable company ( they are so impertinent to charge an exorbitant extra sum per month for enabling the existing wifi on that which i just find annoying ), connected to that is my older fritzbox wifi router that also works as a network storage with a single USB disk to it ( but it has no NFS functionality which i miss ), and connected to this are my computers and a small beaglebone as MPD audio server. my backup consists of numerous USB disks i keep changing when i happen to think of it.
now i want a freenas raid system for my data ( hate changing disks all the time and manually backup. easy snapshotting really is something i dont want to miss anymore ) and a more energy saving design, eliminatin beaglebone and fritzbox as the cable router also can work as a switch for my existing computers ( i am an atypical kind of admin i think, i only have 1 linux and 1 windows box ). i thought about getting some small factor energy saving board ( maybe even ARM ), connect my disks, a wifi card and a soundcard and use it as always-on accesspoint, mediacenter ( with hdmi ), storage and the possibility to add an encrypted array.
I do know how to do this all on linux, even on a pi or beaglebone, and build a system that does exactly that ( very slow on arm boards though ) , but i really like the undoubtetly higher security of BSD and the easy handlingh of FreeNAS. as i said, i am lazy with my stuff at home but paranoid enough to want it safe by all means.
did somebody do something like that, build a kind of green all purpose box? is there a plugin for wifi cards? or how to implant which working drivers for which wifi card into the freenas BSD OS? i want to switch on my computers ( that have and use a lot of power ) only when really needed, not for watching netflix, surfing and stuff.
Constantin
Vampire Pig
The closest thing I can think of is an Apple Extreme base station. It's a simple router, 802.11ac access point, 4-way unmanaged gigabit switch, and potentially a very slow and simple NAS server. AFAIK, none of them have ever been pwned other than via WiFi-consortium-related issues like WEP/KRAK/etc. I use one of my ABS' to serve up media content to my Sonos via a bus-powered burner drive.
You'd have to do your media server separately, however. That's where the FreeNAS might come in, though I have no idea how to implement PLEX via jail, etc. The C2750-based boards that iXsystems uses for the mini and mini XL are a good start re: power efficiency but I have no idea how you would add usable HDMI and/or sound out.
A NAS and a router/firewall do not belong in the same box. That is why FreeNAS doesn't do firewalling and pfSense doesn't do NAS.
Constantin
Vampire Pig
Agreed, hence my suggestion to use one box as his WiFi access point, switch, and router, the other as his media server and NAS. Though combined NAS / media player / transcoder / Plex host / etc. and low power don’t usually overlap too much on a Venn diagram.
I use a Mac mini to serve up content from the NAS, that way the NAS can focus on being a NAS and I can turn off the Mac mini whenever I’m not using it. But I understand why some would want to combine the two.
