mobrien118
- Jun 22, 2020
First, let me say that I'm absolutely loving this approach that TrueNAS SCALE is taking. I've been playing with it for several months now and appreciate being able to play with the Linux underpinnings.
I made a "mistake" the other day (just wanted to see what would happen) and ran "apt full-upgrade -y". This, of course, proceeds to force upgrade packages and settles dependencies by "forging ahead". Ultimately, it removed these essential packages:
Obviously, those are needed for TrueNAS to function. Some were replaced by alternative packages, while others were removed. I was foolish to not take a snapshot, first, but NBD, this system is expendable or I wouldn't have done this in the first place.
The simplest "test fix" I've tried is to to simply install the "truenas" package (and I was waiting to post this to see if 21.04 would fix it on its own) and I get some dependency errors that are tricky to resolve, on their own:
I notice that python3 has progressed to the 3.9.2 version, which is marked as incompatible, and doesn't have a backported version available. That's pretty straightforward. I might try to force it through to see just what happens with that version of Python and what breaks (maybe someone here already knows)
The other two (libnvpair1linux and libzfs2linux ) are a little trickier, since they seem to have been removed from Debian completely and, presumably, replaced by other packages or features. If they are specific libraries or binaries, obviously whatever features they provide will be broken unless "truenas" is updated to use whatever replaces them long term.
I guess this is the downside of using Debian's "testing" channel as your base, and I assume you're just mirroring their repos, not snapshotting them.
Is there anything I can do to help with this? My system is running, so I can do anything but reboot. I tried this same test on a test VM and after doing this and rebooting, ssh isn't on and the main screen keeps cycling:
Thanks!!
cifs-utils fuse libnvpair3 libuutil3 libzfs4 libzpool4 middlewared migrate93 nfs-ganesha nfs-ganesha-gluster nfs-ganesha-vfs openzfs python3-libzfs python3-midcli truenas truenas-samba zectl zfs
The following packages have unmet dependencies: python3-libzfs : Depends: libnvpair1linux (>= 0.8.2) but it is not installable Depends: libzfs2linux (>= 0.8.2) but it is not installable Depends: python3 (< 3.9) but 3.9.2-2 is to be installed zectl : Depends: libnvpair1linux (>= 0.8.2) but it is not installable Depends: libzfs2linux (>= 0.8.2) but it is not installable E: Unable to correct problems, you have held broken packages.
(He's dead, Jim)Login incorrect
Login incorrect
Login incorrect
Thanks!!
