Shroom
- Mar 19, 2014
Hey guys. Haven't posted in a while but I'm finally getting around to building an Avaton FreeNAS server and I have a couple questions.
My idea was to run the mini-ITX C2750 Atom SuperMicro board which seems perfect for FreeNAS, but I thought why not take is a step further since the hardware seems more than capable, and run an ESXi hypervisor with FreeNAS on top as well as possibly some other fancy shenanigans (pfSense, maybe a FreeBSD install, who knows) so as to get some hands-on with some more complicated stuff that may turn out to be useful as an in-home all-in-one server.
My main question is this: if I use one USB 2.0 drive in the on-board USB (3.0 - and I know people have been able to run this port in 2.0 on this exact board specifically for the purposes of FreeNAS being able to use it) header, and partition it out for multiple uses, can FreeNAS still run just fine with its own little partition, with ESXi being the main one? I figure this would be the most efficient and cost-effective set up since FreeNAS doesn't need all that much space, and would allow me to use one USB stick as bootable storage for any VMs I want to run. But I am not sure how FreeNAS works in this configuration.
Secondly, and this is slightly less straightforward, if I were to use the newer SanDisk Ultra Fit USB 3.0 flashdrive, which is significantly faster which would improve its performance as boot media, could this be run as a USB 2.0 device and work for FreeNAS, until such date that FreeNAS can use 3.0, and then later be set to run as a (faster) USB 3.0 device?
Thanks in advance.
Thanks in advance.
