Boot Volume still Degraded after replacing and resilvering (I think)
aptoumanoff
I did try to search and found many boot mirror issues, but none that helped me (in hindsight. If I'd followed instructions when the volume was initially degraded, I'd be fine).
A few days ago my boot mirror became degraded. I ordered replacement USB drives and backed up my config. When my new drives arrived I simply pulled the bad boot drive, put a new one in, and booted up. I then attached the new drive to the mirror and am now in this situation. I realize I should have replaced, not attached, and I realize that if I need to I can simply do a clean install and use my config, but I'd like to simply fix the issue if possible instead of starting over.
As you can see below I have two online boot devices and an unavailable device. The unavailable device is no longer physically attached to the machine. How can I remove it from the mirror? When I do this will my system stop saying the volume is degraded? What more information would you like to help me solve this? Thank you.
[root@freenas ~]# zpool status freenas-boot
  pool: freenas-boot
state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
        the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: scrub repaired 0 in 0h0m with 0 errors on Thu Sep 15 20:08:13 2016
        NAME                      STATE     READ WRITE CKSUM
        freenas-boot              DEGRADED     0     0     0
          mirror-0                DEGRADED     0     0     0
            da0p2                 ONLINE       0     0     0
            12264598356024334089  UNAVAIL      0     0     0  was /dev/da1p2
            da1p2                 ONLINE       0     0     0
errors: No known data errors
edit 1: system information
Build FreeNAS-9.10-STABLE-201604111739 (896cc83)
Platform Intel(R) Atom(TM) CPU C2550 @ 2.40GHz
Memory 16328MB
joeschmuck
Old Man
The easiest thing for you to do is reinstall FreeNAS 9.10 and then restore your configuration file. As far as I can tell, you can't fix it via the GUI.
SweetAndLow
Sweet'NASty
Just reinstall, its way faster.
joeschmuck
Old Man
The OP only posted the one time, 3 weeks ago. Maybe they solved it but never posted it.
