bhyve uses 10-15% idle cpu
Kennyvb8
Hello there
after updating to FreeNAS 11.1, my bhyve VM's uses 10-15% in idle, where in FreeNAS 10 they used 0.1-1% in idle
what has changed ?
Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
16265MB 1800Mhz
FreeNAS-11.1-RELEASE
Kennyvb8
corv
Unfortunately the bug report is private.
Has there been any progress?
Kennyvb8
Nope. No progress in the bug report.
adrianwi
Can the bug report be made public? I have a bhyve VM that's always using at least ~15% CPU, even when it's doing nothing.
bhyve seems to be far more processor intensive that vbox was running in a jail.
Kennyvb8
Not really no, my full log is in that report, and it was the developers that made it private. so think theres some info in there the public shouldent see
adrianwi
Ok, thanks for raising the ticket. If you can keep us updated in this thread? Happy to provide anything that might help resolve.
Kennyvb8
think actully you should make a bug report, maybe they eventually merge them then, and maybe do something..but sure i'll keep this thread in the loop
D
dlavigne
Guest
It will be made public once the dev is finished with the debug and removes it.
Kennyvb8
Hmm new update is out.. but cant see its on the fix list.. anyone upgradet yet ?
D
dlavigne
Guest
Looks like that ticket got moved up to the next update (11.2-BETA1, currently slated for March 19).
corv
Just upgraded to 11.1-U4 and still experiencing this bug.
Is there a build in the nightlies that is fixed?
Kennyvb8
sadly no, but sending them debug.log and what they asked for. each time they bump it to next release
corv
Fortunately I have just found a workaround!
Remove the VNC device on the VM and idle CPU usage goes below 1%!
Please add that information to the bug report. Maybe the devs can calm down VNC when it's not actually in use.
fracai
I removed the VNC device yesterday and haven't seen any difference in CPU usage. Did you also restart the VM?
cancel
Hi guys,
Just did the update to 11.1-U4, after trying everything from 11.1-Release to 11.1-U3 and experiencing the bhyve 10-15% issue reported here.
Also before update I removed all the VNC devices from my VMs. Then I did the upgrade to 11.1-U4.
Seems that the workaround with removing the VNC device works ok :
PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND
8861 root 12 20 0 549M 317M kqread 6 2:14 2.02% bhyve: 3_ubuntu1604 (bhyve)
8834 root 12 20 0 549M 116M kqread 3 1:12 1.20% bhyve: 1_pfsense (bhyve)
11532 root 1 20 0 9996K 4432K CPU0 0 0:01 0.34% top
