Hypopheralcus
- Dec 27, 2013
Hi everyone!
I've been runnig a FreeNAS 9.2.0-Machine for a few weeks now. It is for home use (media server with 3 users and about 10 client computers in a single LAN). - It's a ESX-Machine with XEON E3-1270v3, 32 GiB ECC Memory (16 GiB dedicated for FreeNAS-VM), Supermicro X10SL7F and another IBM ServeRAID M1015 flashed to IT mode. I'm aware of the problems with ESX-VM but I have done what possible to prevent problems (e.g. forwarded both raid controllers directly to the FreeNAS-VM, etc.)
Everything is fine with my zpool (6x3 TB at RaidZ2). But I'm still missing a proper backup solution (e.g. if anything really goes bad with the VM or with the disks).
As it's a home appliance I don't really want to build a second machine, so i thought of the following:
I have quite a few empty bays and also a bunch of old (but still working) 2 TB-Drives. now i thought of just plugging them into the bays and building a new backup-zpool (maybe just with Z1? or do i need Z2 for backup as well?). once or twice a month (which is ok for my usage) I'd put them into the server and rsync the working pool to the backup. Then I pull them out again and store them off-site until the next backup.
Of course, that is some work to do but I'm not sure how to build a different solution with limited budget and possibilities?
I could of course also use an old computer of mine (no serverboard, no ECC, etc.) and build another FreeNAS there but I'd either have to put the machine into the same house (bad for backups) or into my office with a VPN-bridge but only at an upload rate of 10 Mbit/sec.
So is there any FreeNAS Guru who could just look over my plan and tell me if that would be a good way to do or if there is something easier?
Thanks a lot and kind regards!
Hypo
Hypo
