pixel8383
- Apr 19, 2018
I need to create a new pool and move my data since I faced several permanent errors on my pool's metadata.
I am going to create a new temporary pool where to move all the data in order to destroy the broken one.
What's the best way to move the data to it? I know I could use
Do you have any other pratical suggestion in order to easily move the data from one pool to another?
rsync
or cp/mv
from ssh (ideally using tmux) but I am unsure if I will be able to copy everything (I guess things will be limited to what the root user/group has access to). As far as I understood, I could use the zfs send
functionality too but I am unsure if this would migrate the broken metadata too.Do you have any other pratical suggestion in order to easily move the data from one pool to another?
