nightshade00013
- Apr 9, 2015
Well the author recommends using x5 etc within xmrig, so that wouldn't cripple the system.
It only cripples the miner leaving the rest of the system to do whatever it wants.
Did you enable it on the Plugins > Installed tab?ok, so it seems I'm the only person here having troubles with the plugin...
after downloading it and setting the plugin as reported, it doesn't start at all...
where am I wrong???
it's from the Plugins > Installed tab that i was not able to make it start...Did you enable it on the Plugins > Installed tab?
If so, you could try starting it on the command line for its jail and see if an error pops up.
'service xmrig start'
that's why i said to do it in the plugin's jail.[root@freenas ~]# service xmrig start
xmrig does not exist in /etc/rc.d or the local startup
directories (/etc/ix.rc.d /usr/local/etc/rc.d), or is not executable
[root@freenas ~]#
no prob. that error usually happens if the permissions of the plugin jail gets screwed up.right, my fault
root@xmrig_1:/ # service xmrig start
Starting xmrig.
su: unknown login: xmrig
/usr/local/etc/rc.d/xmrig: WARNING: failed to start xmrig
root@xmrig_1:/ #
you didn't happen to change the permissions of the jail dataset?
you can verify with the following command in the jail.
ls -l /*
did you ever try the reinstall of the plugin? that usually fixes it, unless the template jail is messed up too
root@xmrig_1:/ # ls -l total 227 -rw-r--r-- 2 root wheel 957 Sep 29 2016 .cshrc drwxr-xr-x 2 root wheel 4 Jan 25 18:44 .plugins -rw-r--r-- 2 root wheel 249 Sep 29 2016 .profile drwxr-xr-x 2 root wheel 47 Sep 29 2016 bin drwxr-xr-x 8 root wheel 51 Sep 29 2016 boot -r--r--r-- 1 root wheel 6197 Sep 29 2016 COPYRIGHT dr-xr-xr-x 13 root wheel 512 Jan 25 18:44 dev drwxr-xr-x 25 root wheel 109 Jan 25 18:48 etc drwxr-xr-x 4 root wheel 56 Sep 29 2016 lib drwxr-xr-x 3 root wheel 5 May 12 2017 libexec drwxr-xr-x 2 root wheel 2 Sep 29 2016 media drwxr-xr-x 2 root wheel 2 Sep 29 2016 mnt dr-xr-xr-x 1 root wheel 0 Jan 25 18:55 proc drwxr-xr-x 2 root wheel 146 Sep 29 2016 rescue drwxr-xr-x 2 root wheel 6 Sep 29 2016 root drwxr-xr-x 2 root wheel 136 Sep 29 2016 sbin lrwxr-xr-x 1 root wheel 11 Sep 29 2016 sys -> usr/src/sys drwxrwxrwt 2 root wheel 2 Jan 25 18:48 tmp drwxr-xr-x 15 root wheel 15 Jan 25 18:44 usr drwxr-xr-x 25 root wheel 25 Jan 25 18:44 var root@xmrig_1:/ #
pw useradd -n xmrig -u 155 -d /nonexistent -s /sbin/nologin
Perfect! Now it works! Just stranged it happend twice...ohh your permission are all good. i reread your error and totally missed it was because of a missing user.
not sure why the xmrig user didnt get installed, but this should work (run in the jail)
Code:pw useradd -n xmrig -u 155 -d /nonexistent -s /sbin/nologin
May i just ask you what the "donate level %" is and what does it happen if i modify it?Perfect! Now it works! Just stranged it happend twice...
Now I have just to understand how to set it better.
Thanks
Inviato dal mio LG-D855 utilizzando Tapatalk
that is how much of your hashing time (1-99%) is donated to the devs. you can lower it to 1, just don't set it to 0 or it will reset to the default of 5.May i just ask you what the "donate level %" is and what does it happen if i modify it?
Can't login tothat is how much of your hashing time (1-99%) is donated to the devs. you can lower it to 1, just don't set it to 0 or it will reset to the default of 5.
not sure where the issue is coming from.Can't login to
https://monero.hashvault.pro/en/#!/
It says invalid password...
I put my wallet public address set on the plugin and as password the "Password for mining pool" (myemail@hotmail.com)set in the xmrig plugin tab.
Where am I wrong?
Yes, seems to be mining, even if it reports in the graphs just a 25% cpu usage (with an i3 I put 0x5, 4 threads,100%cpu usage).(is that normal? Is it set as the max i can mine?)not sure where the issue is coming from.
for password i always put a worker id, not sure if that's required though. "freenas:myemail@hotmail.com"
did you check the api to verify it is mining, maybe the miner couldn't login, so the mining pool website doesn't know your email yet.
i put that in the freenas settings. on the website i used my email, then after my first login i changed the password to something elseYes, seems to be mining, even if it reports in the graphs just a 25% cpu usage (with an i3 I put 0x5, 4 threads,100%cpu usage).(is that normal? Is it set as the max i can mine?)
You put
On the FN plugin tab or as password oh the website?
