jgreco
Resident Grinch
- May 29, 2011
For a quick fix to get all the available, would backing it up and then recreating the iSCSI then copying it back onto the system. Then later on start on a system that uses the CIFS on FreeNAS for all the students and staff? Would that work better for the purpose of the NAS system?
That'd be a ton better. You're doing it the most inefficient way I can think of, see https://forums.freenas.org/index.ph...res-more-resources-for-the-same-result.28178/
EDIT:
I know you keep on going on about multiple iSCSI attachments. What I am doing is a iSCSI to the server and then shares from that one connection. This shouldn't create the issues that would of been caused by the block level write. Would it not?
Correct. One less hazard.
