Blink
- Oct 7, 2014
Hello fellow FreeNASers,
I'm having some trouble trying to auto import an unencrypted raidZ1 volume though the GUI on FreeNAS 9.2.1.8 that was created by a previous version. I'm not sure which previous version exactly, my USB stick died after a reboot. I can however mount it on the CLI with zpool import -R /mnt volume_name and see the data.
I did a search on the forum but didn't find anything that seemed to fit my situation.
Here is a screenshot after the auto import fails (which takes several minutes before failing):
And the Traceback text:
zpool import output:
Any help or suggestions would be greatly appreciated.
Thanks!
Environment:
Software Version: FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
Request Method: POST
Request URL: http://1.1.1.2/storage/auto-import/
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
107. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
158. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
22. return view_func(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/views/generic/base.py" in view
69. return self.dispatch(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in dispatch
236. response = super(WizardView, self).dispatch(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/views/generic/base.py" in dispatch
87. return handler(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in post
297. return self.render_done(form, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in render_done
350. done_response = self.done(final_form_list, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in done
1080. notifier().restart("system_datasets")
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in restart
363. self._simplecmd("restart", what)
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in _simplecmd
239. f()
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in _restart_system_datasets
4908. systemdataset = self.system_dataset_create()
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in system_dataset_create
5031. os.chmod('/mnt/%s' % dataset, 0755)
Exception Type: OSError at /storage/auto-import/
Exception Value: [Errno 2] No such file or directory: '/mnt/iscsi_volume/.system'zpool import output:
[root@freenas] ~# zpool import
pool: iscsi_volume
state: ONLINE
status: The pool is formatted using a legacy on-disk version.
action: The pool can be imported using its name or numeric identifier, though
some features will not be available without an explicit 'zpool upgrade'.
iscsi_volume ONLINE
mirror-0 ONLINE
gptid/326acf61-21d0-11e1-b03f-d48564a10b18 ONLINE
gptid/32d59646-21d0-11e1-b03f-d48564a10b18 ONLINE
gptid/33459bd8-21d0-11e1-b03f-d48564a10b18 ONLINEAny help or suggestions would be greatly appreciated.
Thanks!
