Steven Lopez
- Jul 28, 2016
Was running FreeNAS Corral.
Downloaded key for volume.
Installed FreeNAS 9.10.2-U5.
Volume that was not encrypted works fine, no problems at all.
Error message:
With key and Passphrase
GUI
LOG:
With key, without Passphrase
GUI
LOG:
So where to start?
Do i have to import all disks first?
Then import volume?
Error message:
GUI
Environment: Software Version: FreeNAS-9.10.2-U5 (561f0d7a1) Request Method: POST Request URL: http://x.x.x.x/storage/auto-import/?X-Progress-ID=c88becae-a4f8-4f84-87ff-57d83b47bdf2 Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 105. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 156. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 22. return view_func(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/views/generic/base.py" in view 69. return self.dispatch(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in dispatch 236. response = super(WizardView, self).dispatch(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/views/generic/base.py" in dispatch 87. return handler(request, *args, **kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in post 289. if form.is_valid(): File "/usr/local/lib/python2.7/site-packages/django/forms/forms.py" in is_valid 129. return self.is_bound and not bool(self.errors) File "/usr/local/lib/python2.7/site-packages/django/forms/forms.py" in errors 121. self.full_clean() File "/usr/local/lib/python2.7/site-packages/django/forms/forms.py" in full_clean 274. self._clean_form() File "/usr/local/lib/python2.7/site-packages/django/forms/forms.py" in _clean_form 300. self.cleaned_data = self.clean() File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in clean 943. f.write(passphrase) Exception Type: UnicodeEncodeError at /storage/auto-import/ Exception Value: 'ascii' codec can't encode character u'\xd8' in position 2: ordinal not in range(128)
LOG:
Jun 13 10:35:42 freenas manage.py: [rollbar:1265] Got unexpected status code from Rollbar api: 403
Response:
"err": 1,
"message": "project is not enabled"
Jun 13 10:35:42 freenas manage.py: [rollbar:1097] Exception while posting item ApiError(u'project is not enabled',)
File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1095, in _send_payload
_post_api('item/', payload, access_token=access_token)
File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1138, in _post_api
return _parse_response(path, SETTINGS['access_token'], payload, resp)
File "/usr/local/lib/python2.7/site-packages/rollbar/__init__.py", line 1274, in _parse_response
raise ApiError(json_data.get('message') or 'Unknown error')
ApiError: project is not enabledWith key, without Passphrase
GUI
The following disks failed to attach: gptid/fa90e071-2c21-11e7-ac58-3497f65b22b9, gptid/0cdb47a8-2c22-11e7-ac58-3497f65b22b9, gptid/07f5ebbe-2c22-11e7-ac58-3497f65b22b9, gptid/06e5ff17-2c22-11e7-ac58-3497f65b22b9, gptid/fd4efdec-2c21-11e7-ac58-3497f65b22b9, gptid/fa074c08-2c21-11e7-ac58-3497f65b22b9, gptid/059bd422-2c22-11e7-ac58-3497f65b22b9, gptid/0e35be4b-2c22-11e7-ac58-3497f65b22b9, gptid/018acb39-2c22-11e7-ac58-3497f65b22b9, gptid/0bb46131-2c22-11e7-ac58-3497f65b22b9, gptid/0de2d758-2c22-11e7-ac58-3497f65b22b9, gptid/094c3ee4-2c22-11e7-ac58-3497f65b22b9, gptid/fecc048f-2c21-11e7-ac58-3497f65b22b9, gptid/fc720548-2c21-11e7-ac58-3497f65b22b9, gptid/0465fc79-2c22-11e7-ac58-3497f65b22b9, gptid/0aa4155c-2c22-11e7-ac58-3497f65b22b9, gptid/fc7f3849-2c21-11e7-ac58-3497f65b22b9, gptid/0320a4f4-2c22-11e7-ac58-3497f65b22b9, gptid/fb2c547b-2c21-11e7-ac58-3497f65b22b9, gptid/00179cf5-2c22-11e7-ac58-3497f65b22b9
LOG:
Jun 13 10:27:06 freenas manage.py: [rollbar:1097] Exception while posting item ApiError(u'project is not enabled',)
ApiError: project is not enabledSo where to start?
Then import volume?
